Question about Gateway 500XL PC Desktop
Gateway desktop 500xl stuck in power saver mode
Sicne a power outage
    Problem Solver:
  • 3 Answers
Click start, run and type in msconfig
the menu that appears allows you to start in NORMAL MODE
Posted on Jan 04, 2009
Computer Gateway SX2802-07 PC Desktop keeps entering power save mode
could be power mode is not set correctly. could be clock/battery is low and causing early saver mode? is your pc time/date correct?
is your ac adapter working properly or is it going bad?
Aug 24, 2012 | Gateway SX2802-07 PC Desktop
Gateway 500XL .. sounds like the Power Supply was making a scratching grinding noise.. off/on... I first thought it was the CPU fan and changed it .. not solved... the PC just shut down... maybe...
Very easy to replace power supply as this is most likely the reason for the shut down due to heat. Make sure when ordering new power supply or buying from a computer parts store that you do not relay on them to give you the right one, you have to do your homework, after you get it do not unplug everything from the mother board, take your time and make sure that when you unplug you know where to plug back and wear anti static bracelet.
May 18, 2011 | Gateway 500XL PC Desktop
My moitor is stuck in power save mode. I have done everything..I don't know what the problem is
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Jan 07, 2011 | Gateway 500XL PC Desktop
Need ethernet controller driver for gateway 500xl....
Here is the Gateway Drivers & Downloads Support link. Just click on the link, and when the page comes up choose the "look up my serial number for me" or type the serial # in the box. That will bring you to Your Models Current Updates for it's Drivers & Software.
http://support.gateway.com/support/drivers/dlcenter.asp?cmpid=topnav
PLEASE DON'T FORGET TO RATE MY SOLUTION, K? THX :)
Sep 21, 2010 | Gateway 500XL PC Desktop
My gateway 500xl won't power on
The first thing I would try is connecting a new power supply. If you can borrow one from a friend/neighbor/family member/whatever that would be the easiest/cheapest thing to try first. Also make sure all the wires are connected to the right places and securely connected.
Jun 04, 2010 | Gateway 500 XL PC Desktop
STORM HIT COMP AND WON'T BOOT
In all likelyness your motherboard at a minimum is dead. Take it to a technician to check and submit a claim through your house insurance
Jun 27, 2009 | Gateway 500XL PC Desktop
I am upgrading memory to my gateway 500xl desktop, how do I open the case?
Find your computer on the Gateway website and download a manual which will show you how to open the case.
http://support.gateway.com/support/supinfo/index.asp?pg=2&file=dt.html
Jan 29, 2009 | Gateway 500XL PC Desktop
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
Gateway 500XL PC Desktop Logo
239 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
