We put running shoes in the dryer to dry and the dryer started.. then stopped and could not get it to start
You probably blew the thermal fuse. Here is the part to order.
Remove the back panel and the fuse is located on the bottom left side.
SOURCE: My Electric dryer will not start.
you might have something stuck in the impeller. if there isn't anything stuck, you might require a new motor
SOURCE: GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
SOURCE: Bosch Axxis WTL 5400 Electric Condensation Dryer...Lint Filter Light
have you checked the vent line it could be stopped up if the line is bent same affect as the lint filter being full
SOURCE: my Asko T721 Electric Dryer is having drying troubles
Here's the answer:
The dryer has a thermo protection "fuse" that pops-out when the lint filter is not cleaned and air will not flow properly. When the airflow is restricted the dryer gets too hot and the "fuse" pops. Then it will not run unless you stand there and hold the start button in. As soon as you stop pressing the button the dyer stops running.
Clean the filter ESPECIALLY the "internal" filter. This one is behind the lower skirt of the machines face. There are two Torex head screws (T20) to be removed and the skirt comes right off.
Inside you see two red handles that you turn to open the filter door. Open the door and pull out the filter. It is a long metal finned box. Take it to your bathtub and run a ton of water through both ends to remove the lint inside. You'll be surprised at how much.
O K now let's "fix" the "fuse". Here it is likely you will need to pull the machine away from the wall. The fuse is a black plastic button about the size of a penny. It sits in the center of the machine's backside. It faces up a bit and if you have clearance you can reach your arm over the machines top and press it "in" with a finger. It clicks when you do so. This part is a no brainer. The dyer will now start properly.
The hard part to all of this is pulling the machine away from the wall since like me you probably have it sitting on top of an Asko washer. Take your time. You can do it.
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
