Question about Sony BRAVIA KDL-32S5100 32 in. LCD HDTV
Sony bruno screen problem
Small retangler dark spots
2 Suggested Answers
SOURCE: TWO DARK SPOTS IN THE SCREEN
My tv set as the same problem. By doing some research on the internet found out it is the optical block. Very expensive to fix if you do not have extended warranty coverage. Apparently, it is not an isolated case and many many many owners of this set are experiencing discoloration after owning it for a few years. Sony will tell you they don't know anything about it. Visit this web link for detailed information. http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock
There's a lawsuit pending. Sony apparently knew about these defects and they continued selling them. No more Sony for me. I feel betrayed. Whta is worst, when you call Sony they play dumb and treat you like you are an ignorant person. Normal tear and wear they say. Only 4 yrs with this unit and paid more than $3k. Normal? Unacceptable.
Posted on Jan 28, 2010
Dark smudges/spots on my HDTV screen
The model indicated here Sony Grand WEGA KDF-50WE655 is a LCD rear projection and rarely if ever requires cleaning.
If black spots or such are gradually appearing the issue on this model is the optical light engine.
Set uses a LCD engine which the lamp shines directly into and heat from that very hot lamp can damage sensitive baffles inside the engine.
I would suggest also you contact Sony as they have on several models extended the warranty for this kind of issue---Engine is very expensive part and several of these Sony sets were involved in a class action lawsuit--hence they are dealing with them.
Do not take no for an answer if you want them to help you---the hinge that is sqeeks gets oiled...........
Apr 02, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Red Lines through picture when screen is dark, back ground has a red tint. On my 48 "Sony Rear Projection" TV
You can try adjusting the Red color output. (Very touchy adjustment)
If you take off the front cover/speaker cover, there should be a access panel. Behind that, there should be a small square black box with 6 screws on it. This is the focus block. (At least this is where most of them are located)
It sounds more like you may need less red in the mix. There is a screw for each color. R, G, and B. Do not mess with the focus screws, just the ones labeled 'SCREEN.'
Go to an unused input where the screen should be dark. Barely turn the red down in a dark room so that the red spot is at the same level as the Blue and Green.
Use an insulated screwdriver and DO NOT TOUCH the focus block and ESPECIALLY NOT the back of it.
Very HIGH VOLTAGE. I found that out the hard way.
Do not turn any of these up too high or damage may occur and the TV may detect a short and shut off.
I have found that if the three colors are adjusted in a dark room to where the 3 color spots (R/G/B) are just barely visible on the screen at equal levels, there is a pretty good color balance.
I hope this helps! Just be careful.
Apr 19, 2010 | Sony KP-48S75 48" Rear Projection...
Black spots on the screen
CHANGE OPTICAL UNIT BLOCK COMPLETLY
Jan 30, 2010 | Sony KDF-42WE655 Television
Dark area on Sony LCD screen model KDL-46XBR4
This model of SONY TV uses a Samsung display panel, the problem you have is the panel went bad.
SONY was offering an extended warranty to change the panel free, please call SONY to check it out that if they still offer the free replacement.
Sep 26, 2017 | Sony KDL-46XBR4 46 in. LCD Television
Spots on screen
Youlikely have dust inside the optical block on the LCD panels. Cleaning the panels is a tricky job and just shooting compressed air into the block will only redistribute the dust. A qualified tech can disassemle the block and clean the panels
Aug 30, 2008 | Sony KDF-E55A20 55 in. LCD Television
Dark screen on TV
This sounds like a speaker got too close to the TV.
Degauss is built into many tv's check for it in the menu.
Otherwise, yes a TV shop or yourself will need to degauss the TV.
May 14, 2008 | Televison & Video
Sony Trinitron KV35V36 Glass Chip
your best bet if you dont have a warranty on the tv is to get it repaired shouldnt be more then 150.00 you dont want the risk of having to fix something else if you get into the tv.
Nov 30, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
I GET WHITE SPOTS ON MY LCD SCREEN
this is a touchy subject for sony. basically sony has increased the brightness levels for the backlights to have better color tones in thier lcd's. well the downfall of this is the white spots you are experiencing. this is not a defect, you will never get them to go away, the only thing you can do is to turn the backlight and brightness down to reduce the white spots. if you contact sony, there is a software upgrade that will help reduce this issue...
Oct 17, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Dark spot on the top of the screen
May you should have a replacement for that, seems is has a factory damage on it!
Apr 05, 2007 | Philips 51PW9303 51" Rear Projection...
Goldstar 19in TV
First check if the signal source is Ok - Antenna, cable, Cable connector.... One of them is at fault.
Sep 26, 2006 | Sony KV-35V35 TV
Sony BRAVIA KDL-32S5100 32 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
