Question about Porter Cable Hammering
Low voltage electrical current 106 volts not 120 volts.
    Sergeant:
  • 288 Answers
Speed up the generator.
could be a fault regulator
Posted on Sep 11, 2013
Wht kind of current comes out?
The computer's switch mode power supply produces DC (direct current) electricity.
Nov 05, 2012 | Computers & Internet
Malibu 8100-0300-01
Promoters should include useful information. Not just air-head fluff.
Copy following link for actual useful do-it-yourself information such as warranty, troubleshoot, operation tips, manuals.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 21, 2012 | Hardware & Accessories
Briggs & Stratton 12KW Model 040229 LPG Generator. 96 Volts @ the 120 Volts outlet, When I turn the house 2 Ton AC voltage increase to 106 Volts.
Can you manually adjust the voltage on the generator without load?? If you have 120/240 60hz output on it and you are not overloading the unit (amperage), then it may be as simple as adjusting whats called your gain setting for your voltage regulator. Obviously you are seeing what happens when it is set too low. Trying raising that setting until it becomes unstable then back it off. Unstable meaning voltage starts jumping all over.
Jun 27, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
Malibu ML600TW. When I bought my home, one loop with 160 watts of lights has melted the 12 ga low voltage wire completely (looks like it was in a fire) for about 3 linear feet. How can this be possible...
You Tube has a plethora of videos on how to start a fire with a single AA battery.
The low volt power packs put out 12 volts AC, so polarity does not matter as far as the _operation_ of the lights. Polarity _is_ a safety concern only in higher voltages and AC systems that are grounded, such as 120 volts, but still doesn't affect the operation of equipment. Best wiring practice is to follow polarity, even on low volt equipment (
This is more noticeable in an ordinary table lamp. The identified wire (the one with ridges) is connected to the screw shell of the socket. That way people don't get shocked when screwing in a light bulb, thus, _not_ following polarity can present a 120 volt shock hazard just with a common table lamp. 120 volts AC kills more people in the USA than any other voltage simply because it is very common and quite often disrespected.
Yes, the old puncture sites need to be sealed. If you have UL listed low volt cable, it is designed to self-seal when the light is removed from the run. However, as the cable ages this self-sealing feature doesn't always function as intended, especially when cold. This is a possible reason why your cable shorted out and melted. If you want to seal the puncture sites on older cable use a product such as this:
http://www.summitsource.com/product_info.php?ref=1&products_id=9976
It's readily available at most hardware stores in the electrical department.
Dec 23, 2010 | Malibu ML600TW - Low Voltage Power Pack -...
Getting Power everywhere is not cord. I have
Try reading the resistance on the coil itself. If your coil is damaged and has a high resistance the voltage will still read 120 volts, becuase there is no current. The voltage drop across the coil is equal to the resistance of the coil times the current. V = I * R. "I" being current. If the resistance of the coil is high because it is broken then the voltage will still read 120V. Another way is to read the current through the coil.
If it is a 1500W fryer then the current through the coil is about 12 amps. 1500/120= 12.5. To calculate the resistance of the coil you would you take the voltage divided by the current. 120/12.5 = 9.6 ohms.
Therefore the resistance of the coil should be very low. It will actually be lower when it is not hot. So your ohmeter should read somewhere between 5 and 15 ohms.
Bob Janelli
Oct 01, 2009 | Kitchen Appliances - Others
I want to re wire an electric motor for low volt
Look on the name plate. If it says under 'volts' 120/240 that means it's dual voltage and you can use either voltage to run.
Sep 25, 2009 | Electric 1hp 1800RPM 56C Frame 12 Volts Dc...
I have a FahrenheatPro. and it doesn't seems to not throw out hea
the baseboard heaters out put goes down a lot more than you would think when used on 120 volts ... thats because not only is the voltage half of what it should be, the current is also half .. so the total power (the product of voltage and current) is one fourth of what it would be if operated on 240 volts .. you are operating at only 186 watts instead of the 750 watts you should have .. so you would have to have 4 times as many heaters for the same heat output .. you likely have the 240 volts available (most houses do) .. there are two phases .. each 120 volts .. when both phases are used together then you get the 240 volts total .. another option is you can use heaters designed for 120 volts .. the current would increase to a little more than 6 amps per heater .. some heaters have a jumper you can move for 120 volt service or 240 volt service... you can use those with either voltage ..
Sep 12, 2009 | Fahrenheat Electric Convector Baseboard...
Inverter output voltage (eg. 96 volts) not if this is an issue
96 volts is low. 106 volts is low. You need to be about 110 to 120 volts optimum. How is your battery input? This is crucial for the inverter to output correctly. If it needs 24 volts DC in Then make sure it's 24 volts. 48 volts means 48 volts. Check the battery voltage and compare to inverter input requirements first.
Jun 08, 2009 | Xantrex Technology DR2412 Inverter /...
Low voltage only or can timer be used for 110 v
1 hp= 750 watts
125 vac = 125 volts alternating current, wall outlets
5 amp= 5amps
125vac x 5amps= 625 watts
a timer is a switch with a clock on it. just like a switch in a lamp cord.
Dec 12, 2008 | Hardware & Accessories
Plinthe chauffante baseboard heaters
take a close look at the tubular element with a magnifying glass. the volts value should be stamped into the element. most baseboard heaters are 240 volt at low, high and medium density. wattage could be from 750 to 1500 watts
Jan 09, 2008 | Fahrenheat Electric Convector Baseboard...
Hammering Logo
121 people viewed this question
Top Porter Cable Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Porter Cable Hammering Expert? Answer questions, earn points and help others
