Question about Dell XPS Computers & Internet
Dell Xps 15 Laptop Battery Not Charging
I'm having a Dell Xps 15 laptop on which i had installed Windows Vista as my operating system. Now the problem is that i'm not able to charge my Dell Xps 15 battery. Yesterday it was fine, then I let my dad use my laptop, and he didn't shut it down, so Vista did it when the battery got low, and now today, the battery does not charge, it stays at 0%. So, can any body tell me that why my Dell Xps 15 laptop battery not charging up? Any one knows about it? Please help me to resolve the above issue. I heard two website http://www.batterietutti.com/dell-xps-15.html http://www.buonabatteria.com/dell-xps-15.html how about it
    Novelist:
    Champion:
  • 233 Answers
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Posted on Nov 02, 2012
That was a big problem, every part of Laptop is necessary for the functioning of it, Here is the blog that might help you:
Posted on Nov 08, 2012
  • Dell Master
  • 7,627 Answers
If you remove the battery and reinstall it, after shutting down of course, what happens? When you re-boot does the software pick up the battery? Is the battery a replacement? Original? Sometime aftermarket batteries will not show up even if they are charging. Is the battery old? Need more info.
Posted on Nov 01, 2012
SOURCE: Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
I have one dell xps m1330 laptop. These are few days my laptop has getting some problems. When I on my laptop it will appear blue screen. I can’t see anything. I had change hard disk and Ram. Some times I have switched on my laptop that time ask press F1 or F2 or F5. When I press F1 it will go to window. What is actual problem? Would you help me?
Posted on Jun 20, 2009
SOURCE: Battery charge issue with Dell XPS M1530
when the battery is fully charged the circuit inside the laptop, automatically. stop charging to increase the the life of the battery,,, thank you,, plz rate me.,,,
Posted on Jun 29, 2009
rockycleofas
  • 21 Answers
SOURCE: corrupted operating system dell xps m140. how to
Dell ships their system with factory installed software and recovery discs.if you formatted using a different , the pre installed recovery are gone. so CALL DELL customer service and have them ship you out a recovery disc its for free, i guess if your still under warranty.
Posted on Oct 30, 2009
tecnomage201
  • 221 Answers
SOURCE: battery of laptop not charging
If the laptop works when plugged in, the power supply is OK. The battery controller is probably the problem, which would mean replacing the battery.
Posted on Apr 17, 2010
My Dell XPS M1530 replaceable battery showing warning sign on the battery icon.
Try to see if there is a BIOS update for your laptop. The last version is A12. That sometimes will fix the problem. If not then it is most likely that the internal charger is built into the motherboard of the laptop is starting to fail. You would have to replace that part or most likely the entire motherboard.
May 04, 2017 | Dell XPS M1530 Notebook
Dell xps m1530 with intel core duo keeps freezing
To further investigate the issue you may do the following.
1.go to control panel --> administrative tools then select event viewer. check on system logs. you might be able to find a clue on why the notebook keeps on freezing after 15 to 20 minutes.
2.please check your virus definitions if its fully updated. If not please update it then do a full scan afterwards.
3. do a windows update on your system if it's not fully updated yet.
4. You may also check or try to remember what has been installed lately. It might be that the application installed have caused vista to freeze.
Or you may also check this link for another user who has the same issue.
hope this helps . . .
Apr 05, 2010 | Dell XPS M1530 Laptop
M1530 a/c adapter plugged in , not charging. replaced battery . same thing.
Understanding battery charging issues
If the <a href="http://www.laptopbatteryinc.com.au/dell-xps-m1530.html">dell xps m1530 battery</a> is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues.
Uninstalling and reinstalling power management software in Windows Vista
In order to correct problems with the battery's power management software, follow the steps below.
1. Click Start and type device in the search field, then select Device Manager .
2. Expand the Batteries category.
3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall .
WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
4. On the Device Manager taskbar, click Scan for hardware changes .
Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the <a href="http://www.laptopbatteryinc.com.au">laptop battery</a> is charging.
Mar 01, 2010 | Dell XPS M1530 Notebook
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Jun 01, 2009 | Dell XPS M1330 Laptop
My dell xps m1530 laptop the eject botton does not work"
are you talking after it boots to windows
if so click for the hardware to be added
If not please explain
Jan 28, 2009 | Dell XPS M1530 Notebook
Drivers for windows xp of dell xps 1530
I do believe that xps 1530 is built in for vista, that only thing that i can suggest you is you can try to look for the specific driver on other xps laptops for example your chipset is intel mobile then choose xp as the operating system or just directly search in support.dell.com
Oct 18, 2008 | Dell Inspiron XPS M1710 Notebook
Computers & Internet Logo
1,026 people viewed this question
Alun Cox
