Question about Harman Kardon CDR30 2-Disc CD Recorder
Recording audio only from an HDTV concert
I have a harman/kardon CDR-26. I have always, previous to HD TV, been able to record the audio only of concerts that I wanted.
I have connected optical cable from the AV receiver (digital out) to the CDR's digital input. When I hit the record button, I get "copy prohibited". I thought this was via the concert. But I get the same message even if I try to record a commercial's audio, just as a test.
Is the cable company doing this ? And why was I able to record before in analog ?
Ken
  • clipper201 Jan 06, 2009
    HifiJohn,
    I read the manual and found the appropriate buttons that change the input modes, i.e., Auto, DTS and Analog. But, none were able to get the signal to the CD-R recorder.
    Thanks again,
    Ken
  • 4 Answers
Have a look at the manual for your AV receiver, you may find that you can change the digital output format between DTS mode and PCM(audio) mode. It needs to be in PCM(audio) mode for your CD recorder to be able to record digitally. If that doesn't solve it I can only suggest recording in analogue mode, i.e. taking a stereo analogue signal from your receiver to the analogue inputs of your CD recorder.
Hope this helps
HifiJohn
Posted on Jan 05, 2009
I have a Harman Kardon crd20 and when trying to record i'm getting "no audio" what is the problem? And is it possible to get a manual?
"CRD20"
A simple web search, which you could do yourself, for "Harman Kardon CDR 20 manual" finds several.
http://www.retrevo.com/support/Harman-Kardon-CDR-20-CD-Players-manual/id/386dj191/t/2/
Look for "no audio" in the manual. It occurs twice.
Aug 27, 2011 | Harman Kardon CDR20 CD Player
Hi dear. how can connect my dvd to hamman kardon
connect tv video in to kardon video out (tv audio in to kardon audio out) dvd audio and video out to kardio audio video in. and if you what to record also signal from tv. make a cable from tv audio / video out to kardon audio / video in.
Apr 06, 2010 | Harman Kardon AVR 135 Receiver
Does anyoe know how to record from LP to cd?
Use your tape out, or another line out signal from your preamp.... if possible - OR Sometimes you can pull out some connectors on the back of your amp (a Metal joint kindathing ;), to break signalpath between preamp and poweramp if its an integrated amp -
Use preamp out signal to feed your cdr ( Main purpose is to equalize out, the RIAA correction on a record)
Have you tried to google your question ? Lots of fine guides out there!!!
Jan 14, 2009 | Harman Kardon CDR2 2-Disc CD Recorder
Harman karadon cdr26 recording problem
try to download and install a clean version of aspi32 drivers,  http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi32_exe.htm
Nov 24, 2008 | Harman Kardon CDR30 2-Disc CD Recorder
Blank cds don't work
Are you using cds labeled music? These are formatted for cd audio home recorders. Data cds for computers will not work. If in doubt, usually on the packaging it states for home audio.
Oct 27, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
HARMAN KARDON CDR-26 CD RECORDER/PLAYER
You need to clean the laser lense, if that doesn't work you need a new laser pickup. Check first, but from memory you need a sanyo sfp151 17 pin laser. Costs around $25.
Mar 08, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
Harman kardon CDR 26 cd recorder
It's the belt from the spindle motor to the gear. It's worn and can't grip the spindle anymore. If you elp it to start off it works. Open the unit, remove the cd tray and it's underneath at the front. You can replace with a similar size elastic band.
Nov 14, 2007 | Harman Kardon CDR2 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
152 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
