ASUS G50Vt-X5 Laptop Battery Not Charging
I'm having a Asus G50Vt-X5 laptop on which i had installed Windows Vista as my operating system. Now the problem is that i'm not able to charge my asus G50vt-X5 battery. Yesterday it was fine, then I let my dad use my laptop, and he didn't shut it down, so Vista did it when the battery got low, and now today, the battery does not charge, it stays at 0%. So, can any body tell me that why myASUS G50Vt-X5 laptop battery not charging up? Any one knows about it? Please help me to resolve the above issue. I heared two website http://www.buonabatteria.com/asus-g50vt-x5.html http://www.batterietutti.com/asus-g50vt-x5.html
    Novelist:
    Champion:
  • 233 Answers
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps.
Posted on Nov 01, 2012
5 Suggested Answers
SOURCE: Built-in webcam in ASUS G50vt
happend to me too..hahaha!! i got it when i upgraded to windows 7 .. 2 fixes that i tried and worked with .... 1:) you can downgrade back with your restore cd install everything ... then upgrade to windows 7 .. for sum reason it worked.... or 2:) you can download MANYCAM .. a free app that lets you play with yer webcam ... add graphics and stuff... and flip the video ... *wink wink.. heheh. hope it helps
Posted on May 19, 2010
  • 66 Answers
SOURCE: I bought this from a
Hi, Try on of the following. Let me know if you succeed.
AWARD_SW
j262
HLT
SER
SKY_FOX
BIOSTAR
ALFAROME
Lkwpeter
j256
AWARD?SW
LKWPETER
syxz
ALLy
589589
589721
awkward
CONCAT
d8on
CONDO
j64
szyx
AMI
BIOS
PASSWORD
HEWITT RAND
AMI?SW
AMI_SW
LKWPETER
A.M.I.
CONDO
Posted on Apr 07, 2011
Geekman
  • 32281 Answers
SOURCE: ASUS netbook 1005 HA charger won't stay in to keep charging battery
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Aug 08, 2012
Geekman
  • 32281 Answers
SOURCE: When your Laptop batteries are fully charged is it a good idea to keep the adapter on?
Remove the adapter when the battery is fully charged, you do not need to have the adapter connected all the time.
Posted on Sep 11, 2012
Dark horizonal lines
Hi! Only at booting, or all the way using the PC?
Mar 05, 2014 | ASUS G50 G50v G50v-x1 G50vt-x5 Series...
Logo touchpad not enable
You can download the device drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select drivers that matches your Windows operating system. Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Oct 05, 2012 | ASUS G2Sg-A1 PC Notebook
Asus x58c factory settings
You maybe able to install the audio driver.
You can download the audio and device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : -http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 23, 2012 | ASUS Computers & Internet
Hiii!! i have a asus G50vt and i dont have the webcam drivers... where can a download it????
hello, get them from here:
http://support.asus.com/Download.aspx?SLanguage=en&m=G50Vt(BestBuy)&p=3&s=133
chose OS and download it, pls first install chipset driver , if u use windows xp right click on setup -proprites-compatibility-window xp
Sep 23, 2011 | Computers & Internet
I am using asus notebook model A6JC originally it came with winxp but since i ve installed windows vista m unable to find driver for it. i ve tried alot but to no avail. its hardware id is as USB\VID...
You can download the device drivers from ASUS WEB site.Select your model motherboard/computer/laptop, and make sure you select driversthat matches your Windows operating system. Please click on this link to theirWEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Jul 24, 2011 | ASUS A6Jc Notebook
In which website i found ASUS P5PE-VM motherboard series all driver for windows 7 & Vista.....??> free.............if u reply it will be helpful for me....
You can download the drivers from ASUS WEB site. Selectyour model motherboard/computer/laptop, and make sure you select the Windows XPor Vista version of the drivers that matches your Windows operating system.Please click on this link to their WEB support site : - http://support.asus.com/download/download.aspx?SLanguage=en-us
Feb 08, 2011 | ASUS P5PE-VM Motherboard
I have bought a new asus laptop and it has no operating system installed. I have purchased a separated os installation disc..how can I install my os on my new asus???
Hi !
I have a blog on how to install Windows XP operating system and it is just the same with other operating system like windows vista and windows 7. Here is the link http://www.fixya.com/support/r7410371-reinstall_windows_xp_or_installing_clean.
I hope it helps you. Good Luck and thank you for using FixYa !
Jan 07, 2011 | ASUS Computers & Internet
How i installed asus laptop camera
Jan 01, 2011 | ASUS Computers & Internet
My bluetooth is not working on my F3S Asus laptop. i have read that me recently re-installing windows is the cause, but how do i get it to work again?
Installed the bluetooth driver according to your operating system installed.
For windows Vista :
http://dlcdnet.asus.com/pub/ASUS/nb/F3E/Bluetooth_vista_070514.zip
For windows XP:
http://dlcdnet.asus.com/pub/ASUS/nb/Drivers/Bluetooth/XP/V5.10.14.6/Bluetooth_XP_071130.zip
Note: pliz on your bluetooth button if Bluetooth button is available on your Notebook.
Dec 26, 2009 | ASUS F3SC-B1 Notebook
World of Warcraft laptop Issues
OK i play WoW and what your experiencing is the patching of the game and yes there are alot of patches. Keep on patching till your version is 3.1.2.9901
May 25, 2009 | ASUS G50VT-X6 PC Notebook
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
