Question about Neff B1421 Electric Single Oven
Change light-bulb How do I change the light bulb in my built-in Neff Oven? The model is B1421N2GB.
  • 1 more comment
  • Anonymous Jan 03, 2008
    Neff oven B1691 needs new lamps.
  • Anonymous Mar 19, 2014
    change light bulb b14m62.0gb
  • Anonymous Mar 30, 2014
    how do I change time on clock of a Neff built in oven
  • 944 Answers
You need to remove the whole oven from its cabinet (after switching off the electricity supply). Removing the doors first; (see http://www.youtube.com/user/Apart4u for videos of this) then remove the facia, which allows you access to the two restraining hooks near the top of the sides of the oven. With these slackened off (screws at the front) and pushed back, the oven can be slid out of its housing - be careful, it's heavy - onto a similar height workbench in front of the oven housing. Removing the wiring hatch (2 screws) and the rear panel (6 screws) gives access to the screw in bulb. Hope this helps :)
Posted on May 17, 2007
SOURCE:
I've got a built in double oven, SCD302TS with no light in the lower oven. Replaced bulbs with known good but no dice. Top oven lights when lower oven is opened, so it's not the switch. Any ideas?
i just looked up your model number and when you change a halogen bulb you should buy the bulb and socket or lamp assy. part 14-38-437 and that's the part the bulb plugs into you can't get it anymore,i just was on sears and repair clinic and it's unavailable
Nov 06, 2017 | Ovens
Power supply
it doesnt come with a cable it has to have its own 25 amp cable from your consumer unit or previous oven installation.
Nov 23, 2013 | Neff B1421 Electric Single Oven
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Oven Bulb.
have to call service tech
May 15, 2010 | Neff B1861 Single circotherm super...
How to change the light bulb
unscrew cover glass to gain access to bulb it unscrews normal thread very easy if glass stiff heat up oven for a few minutes and try again
Dec 10, 2009 | Neff B1421 Electric Single Oven
Broken screw of Light bulb stuck in Neff Oven
hi,,
make sure the power is OFF. get yourself a flashlight and a small flat blade screwdriver. okay you have to make a small bend in the old light bulb screw area so you can get a pair of needle nose pliers in there to get that out, you need to get right in between the threads of the socket and the old light bulb, just enough room to get a pier of needle nose to turn the old bulb out, be careful take time
J
Jun 29, 2009 | Neff B1421 Electric Single Oven
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
Neff cooker model b1422nogb bulb replace
Unscrew glass cover anti-clockise, likewise unscrew bulb, and replace.
Apr 28, 2008 | Neff B1421 Electric Single Oven
Change Bulbs in Neff U1661 Oven
You don't need to slide the oven out, just remove the glass covers with a flat bladed screwdriver and then unscrew the old bulbs. Replacement is the opposite.
Bulbs available from Homebase, Wickes, BandQ etc etc.
Apr 27, 2008 | Neff U1661 Double circotherm super...
Neff B1421 Electric Single Oven Logo
745 people viewed this question
Top Neff Ovens Experts
Paul Carew
Craig Butler
Craig Butler
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
