Question about Arris SURFboard SB5120 Modem
Linksys router and modem problems
I just bought a wireless linksys router so i can play xbox live. i followed all of the steps but i could not configure it. I then realized that my Arris modem is USB but it has an ethernet spot on the back. I have been trying many things to try to make my internet on my computer work and my xbox live at the same time, but either 1 or the other works, not both. Can you please help me.
  • 31 Answers
Most cable company's will not allow you to use the USB and the ethernet connection at the same time. You will need to only use ethernet to your PC and your XBOX. Once you have the ethernet cord connected from your modem to the WAN/Internet port on your router you will need to press the reset button on the back of the arris to authorise the router for access. After that is done you will plug you XBOX into 1 of the 4 numbered ports on the router. Then you will need an additional ethernet cord for your PC.
Hope this helps
Posted on Apr 09, 2009
Router set to strict nat router is linksys wrt54gx2 how do i make it open to play xbox live?
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
Jan 15, 2011 | Linksys WRT54GX2 Wireless-G Broadband...
I have a linksys WRT54G, and I'm trying to hook up a wi-fi connection. As of now, my internet is Internet Explorer, and my current modem is a motorola SB5101. The Motorola modem is hooked up directly to...
Hello
Try this
1 disconnect all wires,including power from the modem and router.
2 Find reset button on router usually in the back,need a pen tip or paper clip to hold it in.
3 Hold in reset for 1 min.
4 Reconnect modem first,power up.
5 Reconnect router second, power up.
Try changing the ethernet wire from the modem to the router.
So your going to have your cable coax wire to the modem.Then a ethernet wire from the modem to the router,then a ethernet wire from the router to the computer.
Sounds like you may have one wire in the wrong place.
Dec 29, 2010 | Linksys : WRT54GS Wireless-G Router W/...
It just stopped sending a signal and 5 hours later it started working then stopped when i tryed to lock it and now it wont work again all lights are on i reset it powered it back on prested the reset and...
The only computer I have is a Dell Insprion E1505 laptop and it is connected to a "COMCAST" cable modem. Windows XP, not Vista is installed. I purchased a LINKSYS WRT54G wireless router. I installed the setup disk and connected the modem to the router, and the router to the computer as step one, but when step two had me disconnect the router from the laptop so it could connect via wireless network, it just says "easylink advisor could not establish a wireless connection with the router
two laptops, a desktop PC and my son has Xbox live. I recently bought the Linksys wireless-g router with speed boost and that didn't work. If any of the laptops were on, the other wouldn't work and my son's Xbox live would lag. I was thinking about exchanging it for the Linsys wireless-N broadband router but then I read the reviews and they were horrible. I need something of that sort but something that isn't known for being unreliable and dying.
I bought the Turtle Beach X41 Headset, and it is causing some problems with my wireless connection. Due to a number of reasons, it is not possible to directly hook up my 360 to my modem. So, if I bought a new router that can operate on a 802.11a frequency, would that help or not? My current router is a Linksys Wireless G, 2.4GHz, router. Microsoft has said that an 802.11a frequency router could fix problems with other wireless electronics. If it would help, which router should I buy? I've read a few reviews for the Linksys WGA54AG 802.11a, and everyone says it doesn't work good. Any suggestions on another brand
i tink with these you can do some thing
Dec 19, 2010 | Linksys Wireless-G WRT54G Router
My router can no longer connect to my xbox live. It began as a problem where i had to restart my modem in order to get connection on either my laptop or xbox but now, only my laptop can be connected to the...
you need to register the router to your internet provider so that the modem will always give an internet connection to the router even if the router will be reset.
from that the xbox should follow through and connect to xbox live if you have an open NAT type.
Sep 14, 2010 | Linksys WRT160N Wireless Router
I'm trying too get connected to xbox live but it's
This mainly depends on your internet modem, I use linksys when I play xbox live. Also I use wireless adapter, sometimes an ethernet cable as well to plug straight from my xbox to my modem. Make sure your modem is connected to the internet, and that if your xbox has a signal, or properly connected to it.
Hope this helps a little. Good Luck!
Jan 02, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys router
You haft to set the router to be static for the Xbox IP. in the settings you can sett it for gameing. just click on the gameing tab
Jan 04, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Router
it might be asking for a WEP password which is located on the botom of the router
Jan 04, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys router
unless your computer has an ethernet card it is not going to work, so if your computer is usb then you will need to purchase an ethernet card for it.
Jan 04, 2009 | Arris SURFboard SB5120 Modem
Arris SURFboard SB5120 Modem Logo
503 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
