Question about Shark Vacuums
Shark Navigator Vacuum Motorized floor brush nozzle wires broken and completely disconnected from swival
Wiring pulled apart when swival broke.
LizDahl
  • 75 Answers
SOURCE: electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Posted on Jan 12, 2008
  • 184 Answers
SOURCE: Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Posted on Feb 07, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Vaccum - brush will not turn
Hi.
Your Dyson has A clutch unit this engages the brush roller when you pull the handle back to vacuum.
Check the clutch control knob which is at the bottom left side of machine looking from the front.
It should rotate to drive position when handle is pulled back.
If it doesnt turn the knob by hand to drive & try the machine.
If you still have no brush rotation after doing all this then UNPLUG machine from mains supply.
Now lay machine on its side & remove the sole plate, This is the cover over the brush roller.
Turn the 3 plastic screws to unlock postition & lift sole plate off.
Now try to yurn brush roller using your hand. It should turn freely if it is difficult to turn look for any foriegn object obstructing the roller.
If no obstruction found then remove the brush roller from the machine & check the bearings in the ends of the brush roller one or both may be siezed up if they are then new brush roller will solve the problem.
If bearings are good then either the clutch is faulty or the second belt which goes clutch to motor has snapped & will need replacing.
It is difficult to fully explain the clutch removing procedure,
But there are service manuals available for these repairs at this site
http://dysonmanuals.llc.nu/
Posted on Jul 05, 2008
SOURCE: rug and floor nozzle brush not moving
What I had to do was take apart the vacuum head...which is very confusing, and the manual doesn't tell you how...the "secret" is to use a flat screwdriver to pop out the little wheels...there are two other screws "hidden" beneath them. Be careful as this exposes all the electrical parts as well - make sure you're unplugged! : )
Posted on Jan 04, 2009
  • 294 Answers
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Posted on Jan 17, 2009
I have the shark rotator vacuum and the brushes won't spin
Hello again Lois Victor,
Make and model number always help... Thanks.
If you don't have your manual...
find them FREE at
Shark NV750ANZ Owner Manual
or here..
Shark Rotator NV752 Owner Manual
or by going to
http://poweredliftaway.com/
AGAIN... hope this helps
Carnac the Magnificent
Jan 10, 2018 | Shark Vacuums
Why wont the roller brush turn on my navigator shark NV22L
It could be a bad switch or brush roll motor, a broken belt, loose wire or contact. You must inspect and test all these areas to narrow down the cause.
Feb 28, 2017 | Euro-Pro NV22 Shark Navigator Bagless...
Why does the brush roller work for a second, then stop?
could be a loose belt or brushroll endcaps need to be cleaned
after you check this if it still cuts out its the electronic board
sorry not repairable
here is the belt if you need it Vacuum Belts Shark Navigator vacuums Lift Away Motorized Floor Brush NV350...
Dec 31, 2015 | Shark Vacuums
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
Sep 10, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
How do I remove brush from the NV-22 Shark Navigator Bagless Upright Vacuum?
Remove the screws from the power nozzle and the cover can be removed to get to the brush
Oct 11, 2013 | Euro-Pro NV22 Shark Navigator Bagless...
Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
Oct 21, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My beater brush comes on for 3 seconds and quits working on my shark navigator.
Same thing with my NAV22. Called them. They walked me through some troubleshooting and then they offered to send me a replacement power floor nozzle (the entire bottom piece). They said they don't want us to open it up to replace belts, so if you registered the product when you bought and it's been less than 5 years you should be all set...
Mar 09, 2011 | Shark Navigator Bagless Upright Vacuum
Vacuums Logo
247 people viewed this question
Top Shark Vacuums Experts
JoeVacs
Thomas Perkins
Thomas Perkins
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
