Question about Altec Lansing XA2021 Computer Speakers
Audio controller on XA2021 malfunction
The audio controller on the sub-woofer is totally malfunction.. when i want to high or slow down the sound, only left or right speaker will produce sound
    Genius:
  • 2,985 Answers
These items are not serviceable. If your are electrically minded you could try to find an alternative part But the norm is to replace the whole set up. Or download a suitable software to control through the pre-amp in the computer - www.audacity.com. RealTek97
Posted on May 17, 2007
What r the best settings for a Power Acoustic PEQ-73 7Band passive eq, electronic crossover, sub woofer level control
Depends on your room, speakers being used, size of sub woofer, amp set up ect.
There is no "best setting" for every application. If that was the case a variable control would not be needed.
Some rooms are boomy, which would lead you to turn down low freq's. Some rooms are very splashy, in which case high will need to come come down. Some rooms are very dead in either lows or highs, in which case those freq's would need to be increased.
To get a baseline on what your rooom is like send some pink noise through your system and analyze it with a RTA. (real Time Analizer) There are free apps you can use on your phone or pro audio products that do a very good job. With pink noise being pushed through the system you will see what freqencies are naturally louder or softer in your room. Then you can adjust that real time on your eq and see the changes.
This will set your room to a flat response, however lots of people don't like that sound and want more punch,growl, or clarity. In that case simply adjust the low, mids or highs to your own listening preference
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 22, 2016 | Audio Players & Recorders
The sub woofer had a distorted sound.
the distorted sound coming out of your sub-w is actually originating from your audio unit, Have your audio unit check for possible repair
Oct 31, 2015 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
How many total watts
Hello
The power rating for this amp is as follows.
Two channel: Sub woofer: Min 35Watts
Two channel: Other than sub woofer : 70Watts
One channel: sub woofer; 100Watts
One channel: other than sub woofer: 200Watts.
OK.
Dec 17, 2011 | Pioneer GM-X332 Car Audio Amplifier
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Popping sound from sub woofer
disconnect the woofer and connect a different speaker see if other speaker makes the same pop if it don't then the woofer cone is defected if you have high watts and using stereo on high volume you can damage speakers.
Feb 08, 2018 | Yamaha HTR-5550 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Altec Lansing XA2021 Computer Speakers Logo
94 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Liev Aleman
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
