CHANGES SOURCE BY ITSELF - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Keyboard issues and answers: A problem that is more common than most people think is an issue with buttons on the control keyboards of modern TV sets. Recently for whatever reason I have seen more questions about this so I have composed this answer and solution for these kinds of problems. It can be any button on the set-channel up/down or volume up down-you name it. The symptoms are the same: channel will scan up or down and will not stop-remote control has no effect on this---It can be channel, volume, or even input or menu if the set has those up front or on the side of the set. All these push controls have something in common-beneath each is a tiny momentary push switch-when pushed with the plastic button it performs a specific task (vol up or down etc.). What happens is the afflicted switch beneath the plastic button is bad-when released it is supposed to stop its function but does not. Keyboard or button controlled features have PRIORITY over the remote control, hence the remote will not stop this from happening. Both the remote and the keyboard go to the microprocessor in the se t but the keyboard is first in line. How to resolve this issue? Someone needs to get at the tiny pc board with the buttons and locate the one associated with the issue (ie sound or channel etc) and unsolder that switch from the board-usually just two pins (may be more for mounting only purposes) and then see if set does not have the issue with switch out of the circuit. For the TECH minded with the board out test here the switches with a ohm meter set to high resistance-any reading with button not pressed means a bad switch-seen ones that read 5,000 plus ohms-it may be necessary to unsolder more than one switch to locate the offender here but an open reading with switch not pressed is the rule. I have taken the time to compose this answer as some do not understand what is happening in these types of situations---No magic wand or smoke and mirrors here-have to disable the offending switch to know. The beauty (in my view) of this kind of problem is if found, you really do not have to replace any part-just operate the set with the remote with one button that no longer functions on the set itself-who could ask for more? SD TECH
Posted on Nov 01, 2012
Source changes by itself when watching tv.
Check your buttons on the TV . Sounds like input or source button ( which ever one they call it ) is pushed in & stuck . Only way to make sure would be to disconnect it & see if it still changes inputs .
Jan 12, 2015 | Samsung 46 UN46C7000 3D TV
Lc 42sb45ut
its losing its mind..bury it
Jan 08, 2014 | Office Equipment & Supplies
Tv changing channels on its own
What tv ? You tryed factory reset ??
Jan 03, 2014 | Sansui Televison & Video
Hampton Bay 52-ANT
If you have a ceiling fan, they often suffer remote operation failure as a result of a power interruption. Try disconnecting the power source. Leave the local switches and chains alone. After a brief pause, apply source power again and try remote operation
Jun 28, 2013 | Hampton Bay Dryers
My Samsung HT-E5400 home theater changes source by itself.
i have the same problem and is so frustrating, it skips all sources with a loop that never ends. any fixes yet?
Jan 13, 2013 | Samsung Ht-e5400 5.1 3d Ready Blu-ray Home...
Changes "source" by itself and shuts of on own.
Check and replace its main system memory IC.
Aug 30, 2012 | Samsung SlimFit TX-S2783 TV
JVC KW-xr810 source changes by itself/randomely. IS it a swc problem with my Tacoma?
I would suggest you install a 12 Volt power filter to the device in question, this will filter out any spurious electrical noise that may be triggering this problem, These filters are available on line and any auto sound supply store or center.
Jan 15, 2012 | JVC KW-XR810 Car CD/ MP3 Player
My TV changes channels or source by itself. I
This may or may not be your solution.
The tact switches (push buttons) mounted on the circuit board may need to be replaced (old, worn, sticking). These are the buttons that are pressed in when you use the controls on the television set (volume, menu, channels etc.). Try removing all of these switches (don't remove the remote sensor). Don't remove just the channel switches.
If you have a remote than you don't 'have' to replace them, only if you want to control the tv from the set itself. After you remove them see if you have the same issue. If so you may need a new control IC chip.
A repair shop will charge about $75 to replace the buttons. If you have the tools and knowledge than feel free to do it yourself. To remove mine, I just used pliers and was careful. However to replace them you will need a soldering iron.
Mar 02, 2010 | Norcent Technologies LT-2722 27 in. LCD...
DIstorted picture for 480p input only
Many set have two differant convergance settings one for 480 and one for1080 this is because when it changes mode the set runns a differant frequencys, what may have happened is you have a cold solder joint somewhere that takes this fifteen minutes to corect itself, might want to start by resoldering the convergance and high voltage curcuits
Jan 02, 2008 | Toshiba 57H81 57" Rear Projection...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
