Question about Kitchen Ranges
Samsung range how to clean between glass on oven door?
How to clean between glass on oven door? what cleaner to use? Cook top cleaner ok? k
  • 1314 Answers
SOURCE: my manual clean oven range
you really don't need to remove them if your nervous just turn the power off at the breaker but they wont hut you as long as the oven isn't on
Posted on Jan 18, 2008
aborcass
  • 2651 Answers
SOURCE: GE Profile range oven door
foil was just protective heat tape, there is a track across the bottom of door that is holding it up,
Posted on Mar 20, 2008
  • 1314 Answers
SOURCE: Clean Oven Door Glass
To remove oven door:
1. The oven door is held to the oven door hinges by two
screws. (One in each hinge.)
2. To remove the oven door remove the two screws.
Two screws
3. Close the door to the broil stop position and lift up.
then remove the door handle and take out all the screws around the edges of the door and pull the out side cover from the inner but a word of caution there are about three or 4 pieces of glass they are tempered and about 100 bucks a piece and most times they wont get real clean and will get messy again
Posted on May 24, 2008
  • 409 Answers
SOURCE: broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Posted on Sep 13, 2008
Using a long stick/tool, attach a cloth to the end. Remove the drawer and look up at the oven door. There are 2- 3 openings that are big enough for you to reach the mess. Make sure that whatever you are using to clean the glass will not stay stuck inside, so make sure its attached securely. I used the end of back scratcher with a thin cloth attached to it. After a few attempts, I was able to completely remove the stain that was caught between the two panels. AND... I didn't need to remove any screws or dismantle the door. This could void your warranty.
Posted on Feb 17, 2009
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Downdraft
I would leave it alone, taking the oven door apart is a real pain in the rear.
May 24, 2017 | Amana ARDS802 Electric Kitchen Range
OUR HOME WE BOUGHT CAME WITH A RANGE, BUT NO MANUAL, WHERE CAN I GET A COPY OF THE MANUAL FOR THIS RANGE?
You will need to find the model number to get a manual. http://www.geappliances.com/service_and_support/literature/ provides a search box for looking up the manuals. For GE ranges, the model number could be in several places: on the frame behind the warming or storage drawer or kickplate, on the left leg behind the warming or storage drawer or kickplate, on the frame of the oven behind the door, under the left front surface burner, or under the lift-up cook-top at the center or on the right hand side.
If you clean the oven with non-abrasive products and avoid the spray on oven cleaners, you are unlikely to damage the surfaces/range even without the manual for your range. (Use glass cleaners for glass cook-top.) Warm water mixed with a mild detergent is useful for most spills. Avoid cleaning the seal around the oven door; damaging the seal may cause major problems.
I hope this helps.
Jan 27, 2012 | GE Kitchen Ranges
Clean oven burner
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 23, 2010 | Kenmore 79013 Stainless Steel Gas Kitchen...
The inside of my self cleaning smooth top range
Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
Sep 07, 2009 | Ovens
Hotpoint RGB745 - how to lift cooktop panel to clean underneath?
hey thats not a hard one for you.kill the power to your range [breaker ok]under neath the cook top frount where the top of oven door meets the cook top.in there are screews into the cook top .remove and lift up cook top it is hinged in the back .clean ,then put back together.you got it God bless ,tom
Jan 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
Top of oven door is turning brown
DeBruce Polish will remove these problems on both stainless steel and enamel finishes. DeBruce Polish also works wonderfully on ceramic cook tops. DeBruce Polish is non-toxic, odor-less and non--abrasive, a true eco-friendly multi-surface cleaner. We get DeBruce Polish at debrucepolish.com.
Nov 22, 2008 | GE Profile 30" Self-Cleaning Freestanding...
Cleaning glass on oven door
The marks may be on the inside part of the glass. If so then the door will need to be taken apart for cleaning. You can use a razor blade scraper and glass cleaner to soften the buildup. Self cleaning won't remove if it is on the inside.
Oct 01, 2007 | Crosley CE35100AA Electric Kitchen Range
Clean Inside Door
dont wory kishk help is at hand ,im a profecional oven cleaner ,and would in almost all cases be able to strip the oven door for cleaning .and it want cost the earth
Jun 08, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
698 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
