Question about LG Cell Phones
My phone I placed for charging and the phone does not start up
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 01, 2012
I can't get my phone to work.My battery is good and charged but the phone still doesn't work. It is new.
Kathryn, contact the shop/company from which you purchased it... Customer Support is I imagine the best place to start...
May 15, 2016 | Consumer Cellular Doro 410 Large Text Flip...
My nokia e51 dropped in sea salt water ten days ago, I dried it and opened its cover under the keyboard and cleaned it , it worked very well for a whole week, the problem is now the battery is not...
The sea salt water has made the charging port corrode. So get a screw driver, open the phone and bring out the charging port. The charging port is where you put our charger. Use methylated spirit to brush the charging port and the panel where the charging port is place.
Dry it for 30 minutes and couple the phone and it will start working fine.
Regards
Sep 12, 2011 | Nokia E51 Cellular Phone
My motorola razor says unable to charge bought new battery cleaned out phone nothing works
in the settings menu,there is a place that has a charge time adjust.Turn it off so the charger will start charging the battery.This is a feature so you can set the phone to charge in minutes,if the bat is too dead,then it would need hrs charging.Thats why it cannot start.
Apr 02, 2010 | Motorola Mobility RAZR V3
Have Motorola W 220. My phone suddenly switches off. When i try to restart, it starts for only a few seconds. The phone is showing message "invalid Battery' or "No battery". When i try to charge the phone...
cleen the charging tips & battery connector carefully,some times the moisture placed on it after cleaning try to switch on.if the problem not gone.than u have 2 choice 1-buy a new battery and test it and go to the phone repair shop who take some general cheking on it.
Oct 03, 2009 | Motorola Mobility W220 Cellular Phone
Frozen screen at start up.
this is because of the software problem try to flash it and reninstall the software...it will work fine
Sep 22, 2009 | Cell Phones
Phone wont charge
hi
i would suggest that you turn off the phone, take out the battery, and the sim, get a contact cleaner, spray on the places which have contacts. leave the phone open for atleast half an hour, then put it back together and start charging
hope this helps
RAhUL_hunk
Mar 10, 2009 | Samsung SGH-G600 Cellular Phone
My phone just flashes when I plug it in to charge
take it back to the place u got it most likely it has a warenty lords knows i have traded my in many times
Oct 24, 2008 | Kyocera Strobe K612B Cellular Phone
Switchback doesn't charge
I suggest you buy a new battery, if that dosent work, send it back to Virgin Mobile for repair
Apr 13, 2008 | Kyocera Switchback KX21 Cellular Phone
Phone dead
Here's something quick to try:
Have the battery tested to see if it holds a charge (This can easily be done by using an inexpensive multimeter). Place the multimeter leads on the battery terminals (red on plus, black on minus sign). Set the multimeter to DC voltage, 0-12 VDC. Let the phone charge for 4-6 hours with the battery in. Unplug the phone & take out the battery. Test the battery as explained above - if it isn't holding a charge...then the battery's probably bad (purchase another battery).
It sounds like your're stating that the phone works only when you plug it in, so I'm assuming that the power adapter and the plug recepticle are in working order - otherwise, the phone wouldn't work.
Mar 18, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Lg mobile battery indicator
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Feb 03, 2008 | LG KG220 Cellular Phone
Cell Phones Logo
22 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
