Why does my maytag centennial agitate while it fills
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
The symptoms you are describing are most likely caused by a bad load sensing switch. The relay in the switch sticks and allows the washer agitate before it fills.
A simple check is to access the load sense switch and unplug the wires to it. Then check the operation. I have provided you with the instructions for accessing the load sense switch in the images below. I am also including the checks that can be made if you have a volt/ohm meter. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
Once the console is open the load sense switch is the switch that has the clear plastic hose connected to it. Remove the connector that has the violet, white and the blue with orange stripe from the switch. Then carefully plug the washer back in and start a wash cycle. If the washer does not do anything, you need to replace the load sense switch (part number W10177795). If the washer still agitates, the problem is most likely a failed timer (part number W10243947).
Image 1
Image 2
Posted on Nov 01, 2012
beltronic205
  • 1466 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do I remove the agitator on a Maytag
Here is a nice video:
My Tip How it works: Direct drive washer
Posted on Jul 23, 2010
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
TheMobilian
  • 8220 Answers
SOURCE: centennial washer, will fill with water, wont spin
Easy fix. Lid switch is bad. This is a direct drive machine. Older models would wash but not spin these latest babys won't wash or spin with the lid switch broken. To access te switch you flip up the control by using a putty knife to release each end. Older models had a screw that needed to be removed, not so with the newest ones. The switch has 2 hot wires and a ground wire. Jump them 2 hot wires and see if she runs
Video: How to get into these machine:
How it works
Posted on Apr 30, 2011
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Centennial series stops agitatimg
Usually a top loader will not agitate until the fill sensor is satisfied. If the water has shut off, and is up at the desired level, the fill sensor has done part of it's job. Check the connections there, and at the timer. It may just be a loose connection.
Nov 29, 2013 | Maytag Centennial Series MVWC200XW
Washing Machines Logo
172 people viewed this question
Top Washing Machines Experts
