Question about Sewing Machines
Janome 9000 growls---safety message comes up---handwheel hard to turn
  • Sewing Machines Master
  • 1,564 Answers
You've got something wrong. Call the Janome help line.
Posted on Nov 06, 2012
SOURCE: Janome 9000 willl not work when turned on
My Janome 9000 has always done that. I can prevent it by raising the needle when I first start the machine, getting it to sew quickly or raising the needle and letting the machine sit for a few minutes. I think my computer wants to warm up a minute. As you can see I.m not a technical person but it works for me.
Posted on Jan 08, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
SOURCE: Janome 9000 seems to be jammed.
I had the same problem with my 9000. After my third visit to the repair shop they finally told me to always check my thread uptake lever. I have had no problems since.
Posted on Jan 10, 2010
SOURCE: janome 9000 refusing to start
I'll bet it's the fuse. I had the same problem about a year ago.
Posted on Mar 11, 2010
chrismyers67
  • 53 Answers
SOURCE: I can hear a clicking when serging
Sounds like your looper timing is off. you will have to have your local shop re-time it. Find a shop that gives free estimates first.
Hope that helps,
-Chris
Posted on Jun 06, 2010
Janome JW5622 handwheel keeping getting stuck
how do I use the free motion plate on my janome jw5622??
Jan 26, 2014 | Janome Sewing Machines
I was embroidering on my janome 9000 it jammed and went dead and won't come back on!
Be sure that it's still plugged in and not on a plug in that is controlled by a switch that got accidentally turned off.
Other than that it is likely that a fuse got blown or the power supply died. In that case take it in for repair.
Dec 12, 2012 | Janome Memory Craft 9000 Computerized...
The hand wheel on my Janome 9000 has become very tight and hard to turn. I am still able to sew but something isn't right.
It is very likely that the main shaft bushing on the handwheel side has failed. It is very easy to diagnose. With the top cover removed, one can inspect the bushing for any discoloration seeping from the bushing. If that is the case, the main shaft and the bushing will need to be replaced. Not a big deal, I've done lots of them, but definitely a job for an experienced technician. paul@howellgroup.org
Aug 20, 2011 | Janome Memory Craft 9000 Computerized...
My feed dods have droped down how can we ajust them to raise them.
Usually when you slide the knob to drop the feed dogs they drop immediately. But when you switch the knob back to raise the feed dogs, they won't come up until you rotate the handwheel one revolution in the forward direction.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
I just want to know the price of janome 9000
Dec 27, 2009 | Janome Memory Craft 9000 Computerized...
Janome 5700 handwheel stuck/inside pulley stuck
Best of ......
Nov 04, 2008 | Janome Memory Craft 5700
Janome memory craft 7500
The feed dog will rise as soon as you turn the handwheel one time. Just put the fabric in it and sew. It will come up automatically as long as you have moved the lever to the correct position.
sewman7
May 15, 2008 | Janome Memory Craft 9000 Computerized...
Nov 16, 2006 | Janome Memory Craft 9000 Computerized...
Sewing Machines Logo
76 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
