Question about NAD Audio Players & Recorders
How to connect a CD player to an NAD 3150 amplifier
  • Rob rinier Nov 01, 2012
    Thank you. I have a Rotel 1520 cd player and I was concerned that I would be able to connect properly to the NAD 3150 as I didn't see a cd imput.
  • Rommel Cana
    Rommel Cana Nov 01, 2012
    May Fixya force be with you.
  • 5,807 Answers
These depends on the model of your CD player, use the corresponding
RCA plug or a 3.5mm plug for portable CD player to the Tape Input
of your NAD 3150
Posted on Nov 01, 2012
marsrover
  • 682 Answers
SOURCE: nad 310 amplifier VERY QUIET
take audio out from tv and insert it in aux in in your amp.
Posted on Jul 15, 2008
SOURCE: PreAmp to Amp problem
Sorted it. You have to put the plugs back in the PreampOUt/Main in or it cuts out the pre-amp.
Posted on Nov 19, 2008
  • 99 Answers
SOURCE: SUV500 2-Channel Amplifier: Hi! can I connect another technics cd-player,sl...
yes you can connect another cd player to the DAT input of your amp.
input connections like DAT, TUNER, CD, AUX etc (except phono) is just to differentiate between what sources are connected, the amp cannot tell what source is connected and will output the sound no problem.
as for the remote operation, if the 2 technics cd players are switched on at the same time they're going to do what you command from the remote together but you'll obviously be listening to 1 at a time.
Posted on Jun 29, 2010
c1apton15
  • 3400 Answers
SOURCE: I saw an Amplifier which says its Frequency
The amp will only go as low as 100hz regardless of what input is fed to it.
Posted on Mar 21, 2011
dunnbiker
  • 8546 Answers
SOURCE: NAD C326BEE amp problem. Connected
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
http://nadelectronics.com/products/hifi-amplifiers/C-326BEE-Stereo-Integrated-Amplifier
Page 6 and 13
Posted on May 27, 2011
NAD 3150 cuts out
Hello. Slapping and it working is a tail sign that there is a loose connection, bad solder point, loose wire. When a circuit board gets hot, solder joints separate and an opening occurs in the circuit. Open it up and get a visual. Look for cold solder joint, make sure all the connectors are secure. Good Luck
Feb 13, 2014 | Audio Players & Recorders
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
Looking for the nad 3150 full tecnical specs
http://nadelectronics.com/index
Contact tech support
Nov 06, 2009 | NAD C325BEE Amplifier
NAD 3150 doesn't play any sound
I, too, have the 3150 and have experienced problems with it. With me the INPUT knob is touchy and needs micro turns sometimes to get both channels to come through. Also, it sounds like the pots are dirty as I get a scratchy sound while adjusting the knob. I have been told that these units are great middle of the road audiophile units. Actually, for the price of a used unit you can't do better. I just had an NAD 2400 THX amp delivered today and am using the 3150 as a preamp. My girlfriend is not feeling well and sleeping in the bedroom, though, and I can't listen to it :( The few minutes I heard of Steely Dan's Cousin Dupree made me bout **** myself (until I got the dirty looks). Sorry I wasn't more help! Goooooo NAD!
Jun 30, 2009 | NAD C325BEE Amplifier
Nov 18, 2008 | NAD C320 2-Channel Amplifier
Nad 3150 speaker repair or replacement ideas
The speaker can be reconed. What specifically is the problem with it?
Dan
May 21, 2008 | NAD Audio Players & Recorders
222 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
