Question about Canon Cameras
I have a canon rebel xti with a 18-55 and 75-300 lenses. I want to purchase a new body and reuse the lenses. Would the lenses fit on a T4i? Or what body would work?T4i bo
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Yes, they will.
Posted on Nov 01, 2012
SOURCE: CANON REBEL XTI LCD
Your battery is low ...shut the camera in off position and replace with fresh battery
Posted on Nov 19, 2008
SOURCE: photos won't load on zoombrowser with windows vista
I contacted Canon technical services through email. Then we uninstalled everything and reinstalled an it worked!
Posted on Feb 15, 2009
  • 81 Answers
SOURCE: canon rebel xti af assist
Check the camera settings under the tools 2 tab. Scroll down to Custom Functions and check #5 to make sure that it's not disabled.
Posted on Sep 17, 2008
sparkysbox
  • 61 Answers
SOURCE: Canon Rebel XTI W/stabilizer lens
Hello bbridges,
Wow, you asked a REALLY open ended question. But here is a good starting point for Manual mode shooting.
Daytime (Full Sunlight) ISO: 100 (or 200-400 to capture fast motion)
F-Stop: Depends on how much depth of field (DOF) you want The lower the number, the blurrier the background. The higher the number, the more everything in the frame is in focus. Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Nighttime (Track Lights) ISO: 800-1600 F-stop: Again, depends on how much DOF you want Shutter Speed: Depends how much motion blur you want. The higher the number, the less blur you get.
Remember when you are panning to capture something in motion, keep on tracking (moving with the subject) even after you have released the shutter. It will help your stability reduce the chances of unintentional blurring.
My suggestion is to go to dpreview.com or stevesdigicams.com and do some rooting around in the forums. They both offer friendly and helpful advice. Also, check out webphotoschool.com
Better yet, experiment with your camera. Pick a time of day and take a series of photos of the same thing, and only change one setting at a time. Make note of what photo number you're on, and what setting you changed (and what it is). Then, when you look at the photos on your computer, match the photo numbers up with the chart you've made, and you'll begin to see a pattern. This is one of the faster ways to learn by trial-and-error. And, this method sure beats randomly shooting and just spinning the dials hoping to get something good. Try to predict the outcome of the shot before you shoot it. Ask yourself what the photo should look like (light? dark? just right? everything in focus, or just the subject?)
As for your lens, check to make sure the Auto Focus settings in your camera menu as well as on the camera are set correctly. And if all else fails, turn off the camera, remove the battery, remove the lens (in as dust-free environment as possible), and then put the lens back on, the battery back in, and turn the camera on again.
Happy shooting, and hope this helps!
**If this response helped you, please take a moment to rate it — thanks!
Posted on Mar 13, 2009
SOURCE: Help! Cracked LCD display on Canon Rebel xti
Had the same problem myself, I purchased a new lcd from ebay (user name: ProphotoSD). He has tons of factory LCD's, cost around 90$. Please note that if you cracked the clear cover above the lcd that is a separate piece however it wont effect the lcd working (this piece is also replaceable). Then I found a simple tutorial for disassembling the camera body on google. Took me like 25 min, very simple job, just need a very small phillips head screw driver. Hope this helps!
Posted on Apr 07, 2009
Every picture I take has a line going through every picture
Have you checked you lens, there could be a hair line dust scratch on it. Or you have it set on a setting that helps with leveling...yes camra's do have them.
Aug 27, 2013 | Polaroid Studio Series .43X HD Wide Angle...
How to mount 67mm thread lens to t4i body only canon
One side of the reverse adapter has a 67mm thread, the other side has a lens mount. Mount it to the camera body as if it were a lens. Bear in mind that it's intended to screw onto the front of a lens and then mounted onto a camera to put the lens onto the camera in a "backward" position.
Dec 16, 2012 | Fotodiox 67mm Filter Thread Macro Reverse...
IS THE 28-90mmF/3.5-5.6 FIT THE CANON REBEL XTI
Since you already have a Quantaray lens, you should know that Quantaray makes lenses with a variety of mounts. A lens with a Pentax mount won't fit a Canon camera, for example. As long as you get the lens with a Canon mount it will fit the XTi just fine.
Aug 18, 2012 | Quantaray 28-90mm f/3.5-5.6 for Pentax
How do you get to the video mode on the canon 400d rebel xti
There is no video mode on the Xti. The first Canon Digital Rebel to be equipped with video was the T1i, which came out almost 5 years later (2 years ago).
Feb 15, 2011 | Canon Rebel XTi / EOS 400D (body only)...
Will the lenses for a film camera (Canon EOS Rebel) fit a new digital body? Thanks.
Yes the Canon EOS lenses from film bodies will fit and work well on Canon digital bodies.
Depending on the Canon digital body you select the lens may have a 1.6 x factor. Meaning the focal length of the film lens will become a longer focal length. For an example Canon's 50mm f1.8 lens on the APS size digital sensor will translate to an 80mm equivalent. This is great for most people but, getting a good wide angle lens is a bit of a challenge, there has to be a tread off somewhere. There are Canon full frame cameras that this factor doesn't apply, for example a Canon 5D.
Dec 08, 2010 | Canon EOS Rebel XS 35mm SLR Camera
Will Sigma 75-300 f/4-5.6 DL work on my rebel XTi
If the lens has a Nikon mount (as you imply in the post), then no, it will not fit. If it has a Canon mount, then yes, it will work fine on your Canon Rebel.
Jun 28, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Canon Rebel T1i
I have the canon 70 -300 sitting right here beside me on my XTi, it also fits my XSi and all my EOS mount film bodies. one thing about canon EOS lenses and bodies: They fit and work together. Yes there are cheaper lenses, but I just answered another question on this website from somebody who has a 3rd party lens (and a high quality lens ta-boot) that will not work on his canon. This is typical of canon. They do not release all of their codes to 3rd party manufactures. Your friend just bought a premium camera, do not let him put a lesser lens on the camera, he will not be happy and the savings will not be that significant to make up the difference...
Dec 26, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Mar 21, 2009 | Canon EOS Digital Rebel XTI Digital Camera
Lens Compatibility
The XTi does not have a "full-frame" sensor, so vignetting should not be a problem with this lens.
Jan 29, 2008 | Sigma Cameras
Cameras Logo
69 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
