De door senser light... i can't find the senser
Where is this famous sensor? found a rusty magnet but can't see where it fell off of... see a plastic catch broken on the front but it does not seem to be connected to any electrical system to send a signal...
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 01, 2012
  • 62 Answers
SOURCE: My door lock magnet fell out and I don't know whee to put it back on the dispensr mechanism tomake t lock
See other posting
Posted on Jan 01, 2008
SOURCE: Washer - soap dispenser door - Magnet fell out... where does it go
I had the same problem. If you turn the dispenser so that the front faces away from you, look on the left side in the front. half way up there is a space with what looks like a plastic clip that might hold the dispenser to the front bezel. This actually holds the magnet, which can be installed without taking the dispenser apart. Be sure to install (pop in) the magnet vertically so that the long part of the magnet sits next to the right side of the dispenser opening (when viewed from the front) when the drawer is closed.
Posted on Nov 06, 2008
SOURCE: The plastic door catch has
I have had this problem and i purchased one from a spare shop in stalybridge tameside called empire spares the number is 01613386161 hope this helps.
Posted on Apr 15, 2009
SOURCE: Fridgidare Model #LTF2940ESO won't start Error Message DDO
The code means the detergent door is open. There is a magnet placed inside the detergent door cover housing that has probably fallen out. This magnet completes a circuit when the door is closed. It usually happens when cleaning the compartment and can usually be found stuck somewhere on the washer metal body itself or somewhere on the path you took while taking it to wash it out. Take the detergent tray out and dissamble it by pushing open the plastic tabs that hold it together. Look for the small 1"long magnet. If there isn't one. take your tray assembly to a repair dealer and have them put a new one back in. It is just a few dollars and your problem will be solved.
Posted on May 12, 2009
TheMobilian
  • 8220 Answers
SOURCE: HOTPOINT WF541 WASHING MACHINE DOOR CATCH
Check this out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Mar 19, 2010
De , on lg washing machine display?
Its a Door Error. It happens when your door is not closed properly or the side coeners are not clean. It happens even when the rusty part (small magnetic) part is missing from the door then the door does'nt close and gives an error dE. Dont worry get the magnet for the door or you can call the customer service and ask for the engineer to visit you soon. it will cost you around 500-550 rs for the service. Or change the door will cost you around 1000-1500 rs.
Aug 26, 2014 | LG Washing Machines
Up and down light not working when using my sebo x4 not changing levelsthe magnet fell off found it
Look at this video https://www.youtube.com/watch?v=74IxduzYTII
at about 8 minutes, 54 seconds. The yellow wheel with the belt has a magnet on its right hand side, and the grey wheel has a magnet on its left and side. The magnets are sensed by a Hall Effect detector which is the thing at the end of the circuit board.
Maybe the magnet you found needs to be glued back into the recess in the wheel. Probably it needs to be the right way round, so I would look for glue residue on the magnet.
Apr 23, 2014 | Sebo Vacuums
Sensor jammed on 'Back Cover Open'
Hi,there is a little switch or magnetic sensors or light sensors behind the doors on the printers, make sure it functioned properly, if that switch or sensor dont work u get that message all the time,
kind regards
Apr 17, 2013 | Brother MFC-7820N Printer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
We're.,the Senser for. Doors. So inside light.
The sensor for the doors are inside the doors attached to the door latch You have to take off the door panel to get to it.
Jan 04, 2012 | 1997 Ford Taurus
One rusty piece of metal dropped from the middle of plastic cover. Now, the washing machine lost its sensor, it keep showing dE and peep all the time. Unable to process washing. What can I do now, please...
'dE' stands for 'door Error' indicating that there is a problem either with the lid/door lock or the lid/door locked sensor requiring a service call, sorry.That piece of metal was probably part of the door lock ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
Got one from dollar tree, but the install instructions are confusing. Following is the instruction: << Remove the self-adhesive protective film from the LED light and place it in your...
The magnet needs to be less than about 1/4" from the light when the door is closed to activate the magnetic switch in the light and turn the light off. Fix the light to the frame or wall inside the cupboard and the magnet to the door.
Feb 28, 2011 | Kitchen Appliances - Others
My machine lg top loader wf-t7050tp gives me a dE error what does that mean
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
Jan 11, 2011 | Washing Machines
My DSC security system is reading "open" and the trouble buttom is lit up.. I do not have the alarm set up, however, it chimes every time you open the door. It was chiming every 5 seconds, what does this...
First of all go to your security box.Now you will have to find where all the sensors conect to the panell.These area's on the board are called zones such as zone 1 zone 2 and so forth.Chech and make sure no wires have came loose from the screw termanils also make sure their is no corrision (good contacts are key).If this doesent work you will need a magnet find out which zone you are having trouble with such as front door back door window ect.Now their are two different sensers one is a flush mounted senser this will look like a little box on the frame of what ever it is securing.The other one will be a inset one this will be harder to find.It will be inside the frame of what ever it is securing.In any case you wil need to run the magnet over this device and see if the panel will reset.If this hapens then you know that their is something wrong with the orig. magnet.(When you shut the door or window the orig. magnet will align with the senser).Some times the distance between the senser and the magnet will effect the senser.If the senser is a flush mounted senser then their will be some wires you can acess to see if they are making contact.
((((( I DO NOT RECOMENT THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN )))))The next thing to try is to simply look on the panel door and read where it says which resistor it needs and where it goes on the panel in relationship to the correct zone buy the resistor and install it in the panel.
((((( I DO NOT RECOMEND THIS ONE. IF YOU TRY THIS ONE YOU WILL NOT BE PROTECTING THIS ZONE AND SOMEONE CAN NOW BREAK IN)))))The next thing to try is the zone bypass.The instructions on how to do this should be on the back of the key pad door.
The next thing to try is to look in the senser to see if it has a battery.Some sensers have a battery and they need to be replaced from time to time.Now I have been asuming that this is a senser on a door or a window but their are other sensors that are optional on this panel as well.Check all wires on these batterys and make sure all outer housings are securly on the sensors.
If none of this works then you probably either have something wrong with the wireing or the panel its self is faulty.If so contact a security technician.
Jul 29, 2009 | DSC Home Security
WAter fill message will not clear
2 things to check ..when was the last time you properly descaled the unit ? If the waterflow is restricted inside the lines and the boiler ,the interior flow meter signals the computer to show insufficient flow ..clean /descale .
If magnet floats to the top of the small lid that keeps it in the little chamber . If it does not float or partially sinks it is defective ..leaks through a tiny hole in the plastic and water filled the grey magnet with some water (adds weight ) then rusted the strong magnet into rusty magnetic powder and loses magnetic force .
You can use a new good strong magnet to see if the sensor is good by placing it where the old one was .Light should go OFF
The overall important service is to keep the scale out of any machine as much as you can .
Feb 29, 2008 | Saeco Incanto Classic Espresso Machine
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
