Question about Refrigerators
It gets hot not cool - Refrigerators
  • mike dupuy Nov 01, 2012
    the unit looks like new. you can here the liqwood in the unit make bulbling nose
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 01, 2012
    1982 dometic rm100
  • Richard Roth
    Richard Roth Nov 01, 2012
    Typically, it seems that with age, often the ammonia cooling system develops a leak. The entire cooling system can be bought from a few online suppliers, thus making the refer operate like new. Of course, you need to make your own decision if the overall condition of the refer warrants making the investment in renewing the innards. If the interior is clean, is there any apparent rust on any of the visible components? Last time I looked, it was somewhat less than half the cost of an entirely new refer. The RM2820 is a popular replacement for that original model.
Valve setting on a 25hp kaw mower intake and exhaust
engineering standards say around .012" inlet hot and .014" exhaust hot ( air cooled engine )
lowest setting would be .010" hot inlet and .012" hot exhaust ( air cooled or water cooled )
get the exact settings from a mower shop
Mar 25, 2017 | Garden
2010 dodge caravan ac gets cold then hot
2 things come to mind the first is are you stepping on the gas to accelerate when it happens this will be caused by a vacuum leak somewhere in the emissions or under the dash/ second are you standing still and you feel the air get hot if this is the case your cooling system is running hot and the heat is transferring to your a/c condenser and making it hot reducing the cooling effect of the Freon because it is getting hot itself
Aug 25, 2014 | 2010 Dodge Grand Caravan
Car gets hot when Idle
You might check your cooling fan at the radiator; it may not be running. If it's not, track it down (fuse or thermal switch) and fix it!
Aug 07, 2014 | 2007 Suzuki XL7 AWD
Back of laptop very hot and bettery life short
Do you have a cooling pad for your laptop? because many laptops require it. Try using a cooling pad
Mar 24, 2014 | Sony VAIO Computers & Internet
HOT and COLD blending
my last two washing machines, totally different brands and types, did the exact same thing. It must be a new way of setting them up, I don't understand either. I can't get straight hot water. My new one does seem hotter than the old one I had which was very distinctly hot then cold then hot then cold even on hot hot water.
Nov 09, 2013 | Maytag Washing Machines
HOT and COLD not blending correctly
The explanation I have in my file is that powder detergent does not dissolve properly in cool and warm wash cycles unless there is some hot water flow. However, I agree with your assessment.
Nov 09, 2013 | Maytag Legacy Series Top Load Washer
Our danby dwc 283bls is not cooling. The motor
If compressor is running and it gets hot and the unit does not cool the compressor is bad or you have a leak in the system. if you see oil there's a leak.
May 22, 2010 | Danby DWC283BLS Wine Cooler
Compressor working, cooling coils hot, but unit won't cool below
When you say fully charged, did you weigh the refrigerant? These small systems cannot tolerate overcharging by even small amounts because it will result in overpressure on the suction side. If there's too much refrigerant you get hot coils and cool but not cold evaporator. I typically pump the refrigerant into a recovery tank and then weigh it back in to get exactly the amount on the mfg label.
Dec 12, 2009 | True 598-TSSU608ADA SandwichSalad Unit 155...
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
