Question about LG Washing Machines
DE door sensor error light keeps coming on
LG wf-t800C/ WF-T1000C - the DE door sensor error light keeps coming on but i can't find where the sensor is... i have found a little plastic latch on the clear part on the front broken but that does not clip on to anything... and when i was cleaning the back gap between the door and the machine around the hinges, i found a magnet which seems likely to be involved with a sensor BUT i can't find where the magnet should slot in....help... i live in Asia...
drsn
  • 42 Answers
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
drsn777@hotmail.com for more info.
Posted on Dec 15, 2008
SOURCE: Dead LG WF-T8016TP washing machine
Solution # 2 worked for me. I used a 15A "fuses for microwave ovens".
item bar code 0 68938 90277 3. Cost $ 3.00
Thanks
Posted on Apr 26, 2009
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
canbruce75
  • 1776 Answers
SOURCE: LG WF-T700 Troubleeshooting DE blinking
The "DE" code indicates a door open error. This can be caused by the door not closing all the way (this could be because of bent door/hinges or the door gasket bunching up and not permitting the door to close properly), loose electrical connections at the door switch or powerboard assembly, or the door switch itself is faulty. It can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity would mean a bad switch. Also check the door gasket for "bunching" and you can unplug and reseat electrical connections. These are some areas to look at. Be sure to disconnect unit from power before attempting any repair/troubleshooting. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 28, 2009
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
Lg wf-t506 has de error.
i think your machine door switch is damedge........replace it
Jun 09, 2013 | LG Washing Machines
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
DE error is coming on my LG wf-t90z20
"dE" means you have a door latch error. If you've already tried to unplug the machine and that didn't correct the issue, the door latch assembly will need to be ordered and replaced to fix the issue. The latch assembly is just not reading that the door is shut properly even though it is.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2011 | LG WM-2277HW Front Load Washer
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
Lg washing machine WF TS 800 after selecting quick wash, machine will delay washing and says DE, washing will then stop.
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Lg model number wf-t1246tp; error code dE appears on display. however, door is properly shut
Good luck,
John C
Mar 09, 2011 | LG Washing Machines
I KEEP GETTING A dE ERROR ON MY LG TURBODRUM WF-8071TTP WASHING MACHINE PLEASE HELP
Dec 15, 2008 | Washing Machines
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
