Question about SanDisk Sansa m240 MP3 Player
My sansa clip screen won´t turn i can just here the music
When i turn it on i can´t see the screen what can i do to see what´s on the screen it works good i can here music download the olny problem is the screen
  • Anonymous Jan 11, 2009
    My screen is just black... the music still plays though. i cant see anything
  • Anonymous Feb 24, 2009
    i´'be traying everthing... and nothing. i think it´s Stuck
Press the screen in it should work the wires internally are shorting
Posted on Feb 19, 2009
My sand disk sansa mp4 keeps on freezing on the music play all the time and the computer cannot read it
How to Reset a Sansa Clip
The Sansa Clip is a high-quality MP3 player. It holds hundreds of songs and is built for portability. The "clip" allows you to attach it to your clothing or belt while you are working out or on the go. Even the best MP3 players can encounter some problems, and the Sansa Clip is no exception. If your Sansa Clip freezes up and does not respond, you may have to try resetting or reformatting it.
Turn Sansa Clip on. Press the "Menu" (home) button.
Press the bottom of the scroll wheel until you reach the "Settings" screen. Push the center button to choose "Settings."
Scroll down to "Reset All" and select. You'll be asked to confirm the reset. Select "Yes." This option will simply allow you to reset the language and location settings on your Sansa Clip. It will not erase data from the clip. To do a complete factory restore, follow Steps 4 and 5.
In the "Settings" menu, scroll down until you reach "Format" and then select. You will be asked to confirm that you wish to format. Select "Yes."
Wait for the screen to say "Formatting Complete." You have now cleared all the files from your Sansa Clip and reset it to factory settings.
Resetting a Frozen Sansa Clip
Push the power button up and hold it for 20 seconds. Release it, then turn it on again.
Go to the Sansa website and download the "Sansa Firmware Updater."
Select "Run" when the updater installs. (Installation will take less than two minutes.)
Wait for the Sansa Firmware Updater to run through its system test. It will ask you to connect the Sansa Clip to the computer to update your Sansa's software.
Connect the Sansa Clip. Remove it from the computer when instructed. If this process does not unfreeze your Sansa Clip, contact Sansa support at the Sansa Firmware Updater website.
Tips & Warnings
You should download the Sansa Firmware Updater to your computer even if you aren't having a problem with your Sansa. This will ensure that your device software remains up-to-date and free of technical glitches.
Reformatting the Sansa Clip will erase all songs and data on the device. Resetting will simply change your player's settings.
Have a nice day....
Feb 19, 2011 | SanDisk Sansa e260 MP3 Player
Sansadisk mtable file problem
Switching to MSC mode and performing a content backup
When the player does not respond to the software for the media player
in MTP ( media transfer protocol ) mode you can switch the player to
MSC mode in the player as next:
1. From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC.
When having no more screen view, have a hardware MSC selection:
Forcing Sansa Clip to MSC mode, enabling the USB connection mode for the computer seeing the device as a removable disk:
Sansa Clip
1. Turn device OFF.
2. Slide the Hold switch down to Lock (orange color showing).
3. Press and hold the center button while connecting the device to the PC.
Updating firmware
Next update the firmware of the player. This will clean all your files in the player ( have a backup first as told above ) and the software in the player will be updated.
How to update Sansa Clip's firmware, see:
http://kb.sandisk.com/app/answers/detail/a_id/300
Oct 25, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip is stuck on radio, re-setting does not work,
Can you see your screen? If not turn on your player and press the home button. Press up once and play 2 maybe 3 times to get it back on your whole playlist section. It should start playing music then.
Sep 25, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip won't play the songs I loaded on!
I've had this happen a couple of times in the last 6 months. You can get it to play again by chosing the format option from the settings menu. Of course, then you've lost everything you had loaded on to it. Download your music/audio books again and they will play.
Jul 15, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip 4 gb wont turn on
You probably already did this, but here is the proper method to change the backlight timer:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
-Tha mp3 Doctor
Feb 26, 2009 | SanDisk Sansa Clip MP3 Player
Not working 1gb sansa clip
What does that mean - "music db" ? I put all of my music on my 1 Gig and it works great. I put all Harry Potters audio books on my 8 GIG and still have 1.5 gig left for music.
Feb 03, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Jan 02, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa m240 MP3 Player Logo
95 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
