Question about Mitsubishi WD-60735 Projection Television
I have a slightly arched pink & green line accross the top of the screen.
The line is horizontal, translucent, & fairly narrow (slightly thicker than an inch) it's a pinkish color on top, with a blueish green color underneath that. The line is arched in a downward manner, thinner on the sides of the TV's screen & thickest near the center of it. The picture does not seem skewed or otherwise in error, the translucent line appears to be the only trouble.
  • 2 more comments
  • Thomas Brixey
    Thomas Brixey Nov 01, 2012
    It is the correct model number, the set is one from the V39 chassis series of DLP TVs, it is the 60" set.
  • SD Tech
    SD Tech Nov 01, 2012
    Either a issue with the light engine or something on the optical light lens---could also be a gasket for the screens hanging down enough---anything that gets between the rear mirror and the screen will standout like a sore thumb on the screen.t
  • Thomas Brixey
    Thanks! I suppose I should start with checking the gasket--seems like the simplest--then I'll make sure the lens is clean before i look into the light engine.
  • btcstore27 Nov 02, 2012
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
I am wondering if we have the correct model number listed here? If so with the model listed either something is inside like a spider web or that model uses a optical light engine which "might" be able to do this if bad.
Posted on Nov 01, 2012
  • Thomas Brixey
  • 1153 Answers
SOURCE: Horiantal line near top of screen
Suspect the Light Engine part # 939P977020.
Posted on Oct 06, 2007
Shuttle83
  • 1139 Answers
SOURCE: WS55711 mitsubishi RPS - Dec 2002
This sounds like your convergence correction amplifiers have malfunctioned. These Integrated Circuits often burn out after a few years (STK392-110) they can be replaced with a higher version (STK392-150) However it is important to have the biasing circuitry checked to make sure nothing has burnt out as a result of the ICs malfunctioning. If you have a background in electronics you can repair this problem with very little effort, however if you do not have a background in electronics, I would suggest that you have your TV serviced by a qualified TV technician.
I hope this helps,
Thank you,
Shuttle83
Posted on Oct 15, 2007
CrazyLarry
  • 173 Answers
SOURCE: Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Posted on Jan 19, 2008
SOURCE: Mitsubishi VS-60111 picture distorted
how do I manually switch my t.v. from 480i to 1080i on dtv with remote.
Posted on Oct 03, 2008
Bat1956
  • 585 Answers
SOURCE: Phillips Model 60pp920217f
I expect the answer to your question is YES! The convergence amplifiers are a common problem in many projection sets. When you search for the replacements you should find that the originals have been superceded by improved parts. Also be aware that when these parts fail, they will usually damage a resistor in the convergence yoke return path. The resistor must be replaced with one of the correct value or the convergence, though responsive, will be out of range.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Posted on Dec 30, 2008
This is Jon Baker from Sacramento, CA have a TV LG 50PZ55-UA have a lot of PICs that show model of the TV /boards - can you help on which board maybe the problem?
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 21, 2016 | LG Televison & Video
Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line?
Black square on the screen Vizio Gallevia 47" 1080p - Fixya
www.fixya.com/support/t355299-black_square_screen_vizio_gallevia_47
Jan 16, 2008 - Black square sized app. 10"x10" pops up on the bottom right corner of the screen and won't go away. .... Model 42LG70. Why is nothing on screen except for horizontal green and pink pixel line? I am looking at replacing the ...
bad screens display vertical lines with a white background ...
https://www.ifixit.com/.../bad+screens+display+vertical+lines+with+...
iFixitJun 17, 2014 - I am now replacing a screen on a different G2 and I am on the secondscreen. ... A touchscreen smartphone made by LG Released: 09/2013 Model: VS980..... on the rigth side, from the top to the botton has 6/7 black lines.Missing: 42lg70 ‎pixel
Broken LG LCD TV Capacitor Black Screen My Wont Turn ...
? 6:27
https://www.youtube.com/watch?v=EbGiXqBAvvo
Aug 25, 2010 - Uploaded by FixItUrselfDummy
Broken LG LCD TV Capacitor Black Screen My Wont Turn On ...How I fixed my LG TV, Won't turn on or show picture Model: LG42LC7D ...Missing: horizontal ‎pink ‎pixel ‎line
Jan 05, 2016 | LG Televison & Video
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
How do I correct pink and green bands accross HP-R4252 Plasma TV
First of all try, changing the input device to some other and see whether you see the same problem. Then connect your present input to a different TV and see. If you feel the input is ok, and it is a problem in the display, this is a case to be handled by a qualified service technician.
Jul 16, 2012 | Samsung HP-R4252 42 in. Plasma HDTV
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
Picture at top of screen, bottom half is black...middle of screen has horizontal red, green line which is slightly bowed upward. model # is GE 46gw948
Call a good TV Tech and tell him the Convergence Amp IC's need to be replaced. Should not cost over $325.
Jul 29, 2009 | Televison & Video
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Yellow and pink line accross top of screen.
We have aKDF-E42A10 for a bout 2 yearsnow and we now have 13 horizonal lines across the screen, they look like small square dotted lines across the entire screen from top to bottom. It be gan acouple of months ago as 2 of these lines that seemed to move up the screen. I called technical support and he made it sound like he never heard of the problem. I am very upset with sony right now. Anybody know how to fix the problem?ricedog
Aug 14, 2008 | Sony KDF-E42A10 42 in. LCD Television
Mitsubishi WD-60735 Projection Television Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
