Question about Nikon Cameras
Unable to install photo to my computer
Free Nikon D3100 digital Camera driver
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Nikon Transfer or Picasa.
Posted on Nov 01, 2012
  • 79 Answers
SOURCE: Installing digital camera drivers from Nikon View 5 or 6 CD on Windows OS
This document assumes that your computer did not recognize your digital camera after you have installed Nikon View version 5 or version 6 (5/6) using "Easy Install" and then restarted your computer. Nikon View 5/6 compatibility: Windows 98 SE Windows ME Windows 2000 Windows XP Home Edition/Professional Note: Log on as Computer Administrator when installing drivers on Windows XP Home Edition/Professional or as Administrator when installing drivers on Windows 2000 Professional. Cameras that are not supported by Nikon View 5/6 Nikon View 5/6 does not support direct connection of COOLPIX 950, 910, 900, 800 or 700 digital cameras however it will support a Compact Flash card reader which contains images taken with these cameras. Before installation - Before installing Nikon device drivers, make sure the camera is disconnected from the computer. If the Device Wizard launches when you connect a camera, click Cancel to exit the Wizard. - You have turned off any virus-checking software that may be running. - You have exited all other applications. Procedure for driver installation First DISCONNECT THE CAMERA FROM THE COMPUTER and follow the instructions below. Insert the Nikon View CD into the CD-ROM drive, the Select Language dialog box appears. Select a language Select the language of your choice from the pull-down menu. After you select a language, click Next to display the Install Center window. Custom Install Step 1: Select the software to be installed. Select the programs you want to install from the list in the Custom Install tab. Step 2: Install the driver Choose the camera driver you wish to install and click Install. If you have chosen more than one program, the programs are installed in the order of display. - PTP Drivers Select this check box to install PTP drivers. This check box is only displayed if you are using Windows XP. - COOLPIX Camera Drivers (all models except 990 and 880) Select this check box to install the driver for COOLPIX series cameras (excluding 990/880). This check box only appears if you are using Windows 98 Second Edition. - Drivers for COOLPIX 990 and 880 Select this check box to install the drivers for the COOLPIX 990/880 - Drivers for D1 series cameras Select this check box to install the drivers for the D1/D1X/D1H cameras. Install PTP Driver (Windows XP only) Check that the camera is disconnected If you selected the PTP Driver, the installation of the driver will start. The Setup dialog box below is displayed, asking you to confirm that a camera is not connected to your computer. Make sure a camera is not connected, and click OK to begin installation. Windows 98 SE If you are using Windows 98 SE, drivers for all COOLPIX cameras (all models except 990 and 880) will be installed if selected. The dialog box shown right will be displayed. Click OK to continue. When you install the device driver, the dialog box shown below may be displaye
Posted on Aug 29, 2005
Quack
  • 542 Answers
Posted on Aug 30, 2005
chopas
SOURCE: Driver Software
I need to know how to download the driver for my Coolpix L3. How do I get it
Posted on Jul 15, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: Nikon Coolpix L11 camera
FIND THE USB OPTION IN YOUR CAMERA MENU AND SELECT MASS STORAGE OPTION, THAT WILL ALLOW YOU TO CONNECT & VIEW THE PHOTOS LIKE A REMOVABLE HARD DRIVE OR JUMP DRIVE
Posted on Aug 11, 2008
  • 2386 Answers
SOURCE: What settings would you use on the Nikon D3100
Hello
Here are some general guidelines for shooting fireworks:-
Get a good position! Try to determine approximately where the fireworks will be bursting. And get a spot with an unobstructed view of that area. You'll probably need to show up early to get a good spot. Figure out the wind direction and get upwind of the fireworks so that your shots aren't obscured by smoke blowing toward you. Find a spot where you can avoid getting a lot of extraneous ambient light in the picture, as this will cause an overexpose.
Set the camera on the tripod. Don't extend the legs or neck of the tripod. Keep everything close to the ground to keep the camera as steady as possible.
Ensure the camera settings are correct. It is best to set these well ahead of time, as it may be difficult to see your camera controls or your checklist in the dusk or dark. But it's wise to double-check now.
Set your focus to infinity. You're generally far enough away from fireworks that you can adjust your lens focus to infinity and leave it there. If you want to get a closeup of a small part of the burst, you may need to adjust the focus as you zoom in. If you want to include buildings or people in the background, you may want to bring these into focus. Avoid the use of auto focus if possible. Most cameras have difficulty adjusting focus in low light conditions.
Use a smaller aperture. Set the aperture in the f5.6 to f16 range. F8 is usually a good bet, but if you're shooting with ISO 200 film you may want to kick it up to f16.
Turn off your flash. The fireworks are bright enough, and your flash wouldn't effectively reach them anyway.
Take off any filters or lens cap before shooting. If your lens has IS (Canon) or VR (Nikon),Turn it off before shooting. If you are shooting with an SLR or DSLR camera, chances are your lens has the IS (image stabilization) or VR (vibration reduction) feature built in. And if you have IS or VR (it is essentially the same thing, but Canon and Nikon just had to label it differently), then chances are you are used to leaving it on close to 100% of the time - which is generally a good idea. IS/VR is meant to sense the vibration (the shaking of you hands, mostly) and compensate for it. When it does not sense any, it... creates it. Turn it off in order to get sharper images. This tip goes not only for shooting fireworks, but is valid any time you shoot off a tripod.
Frame the picture before shooting. Look through your viewfinder during the first few bursts and figure out where the action is. Point your camera at that spot and leave it there. You don't want to be looking through the viewfinder while you're trying to shoot, because you'll likely shake the camera or your timing will be off. If you're trying to get closeups, of course, your framing will need to be more exact and you'll probably have to play with it more. Once again, frame carefully to exclude other light sources that might distract from the fireworks or cause your photos to be overexposed. 5Keep the shutter open to capture the entire burst. Set the exposure to the maximum length. To get the sharpest image it is best that nothing comes in contact with the camera during the exposure. Use the automatic long exposure of 30 seconds or more. If your camera does not have an automatic long exposure the use of a cable release is OK. Use the BULB (B) setting, which will keep the shutter open as long as the button is depressed. A rule of thumb is to open the shutter as soon as you hear or see the rocket shooting into the sky and to leave it open until the burst is dissipating. This will usually take several seconds.
Spice it up. Even good pictures of fireworks can be boring if there's nothing to distinguish them. You can make more interesting photos by including buildings in the background or spectators in the foreground. Choose your shooting location to try to get an unusual and unique perspective on the show if Possible.
Hope it helps, if so do rate the solution
Posted on Dec 27, 2010
Why unable to upload photos from camers to computer?
probably need to install a driver on the computer
http://www.solvusoft.com/en/update/drivers/digital-camera/nikon/coolpix/l12/model-numbers/
Nov 27, 2014 | Nikon COOLPIX L12 Digital Camera
What can I do when the driver will not install for Nikon D3100
Try NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 26, 2014 | Nikon D3100 Digital Camera
Arabic language
Go to Nikon website on your computer and download the language for your Nikon D3100 camera then use the usb cord to install it to your camera. Any problems with this go to ehow.com and they have other solutions too.
Aug 17, 2013 | Nikon D3100 Digital Camera
Problem importing pictures on pc from Nikon D3100
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer ( http://support.nikontech.com/app/answers/detail/a_id/61 ) or Picasa ( http://picasa.google.com ).
Jul 17, 2013 | Nikon D3100 Digital Camera
Import pictures Nikon D3100 get access denied
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
There is a green light thats on even with camera turned off and also the screen shows a rotating timer. Its a d3100
your Nikon has stuck in a loop and unable to shut down, this type problem should be looked at by camera tech.
Jan 26, 2013 | Nikon D3100 Digital Camera
I am unable to trasfer edited photos from my Nikon D3100 camera to computer
Remove the SD memory card from the camera and insert the SD memory into an USB memory card reader. Plug the memory card reader into the USB port of your computer, the computer will see this as an external storage device, you can then open the image folder and copy the photos from this folder to your computer.
Apr 11, 2012 | Nikon D3100 Digital Camera
I accidentally deleted photos to my NIKON d3100 can I restore the photos
You can try to recover photos deleted from Camera with a camera photo recovery software, recommended asoftech photo recovery as it helped me many times. you can see more info about photo recovery software from facebook:
http://www.facebook.com/pages/Asoftech-Photo-Recovery/126127714100611?sk=info
Here's video tutorial for how to recover deleted photos from camera
Jul 28, 2011 | Nikon Cameras
I JUST PURCHASED A NIKON d3100 FROM YOU - i CANNOT UPLOAD PICTURES TO MY COMPUTER. CAN YOU HELP. THANK YOU. Clyde
You might want to consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
You can download the current versions of all (free) Nikon software from
Feb 17, 2011 | Nikon D3100 Digital Camera
Cameras Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
