I have a GE Adora front laod washer that I need help with. I have cleaned the pump filter, shop vac'ed the hoses, checked the hoses to make sure they are not clogged or pinched and I have hit a de
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
On the GE Adora machines, if the unit is not getting the correct power, the unit will not go beyond the fill point to wash. You will need to replace the "power inverter" on the unit. Here is the part you need to order.
Posted on Nov 01, 2012
blueextc3221
  • 15935 Answers
SOURCE: I have the LG Tromm 27'' Front Loader model WM2277HW
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!
Posted on Sep 18, 2010
  • 96 Answers
SOURCE: Maytag washer won't spin out
Before you try to take the panel apart to remove the timer you need to check that the electrical connections to the pump are o.k. and whether the pump is getting power when it's time to drain. If you have to replace the timer you need to take the back panel off first.
Posted on Mar 13, 2008
hiltonjug
  • 612 Answers
SOURCE: ge profile washer WPSR3100W1WW won't agitate
I see this pretty regular. You have a bad transmission. This is very common with the older GE's. To replace the transmission will run around $340 / $400. Not sure about your area. Just be glad you got this much use out of it, you are one of the very few that have. From 1998 till 2007 I owned my on repair company where I did GE's warranty work in my area for them. During that time period. When I found a GE washer under warranty doing what you are describing. GE would warranty the whole machine. They would have me destroy the machine after I would deliver the customer a band new one. GE knows they had a bad transmission and it cost them a lot of money. It was cheaper for them to replace the washer than have me repair it. The transmission list price was $298.00 back then. A word of advice, when you replace it. Buy a Whirlpool, Kenmore, Maytag. These brands hold up the best. I have the least service calls for Whirlpool and Kenmore. Both are made by the same people. Kenmore is made for Sears. Good Luck.
Please rate this solution if helpful. Thanks
Posted on Aug 21, 2009
SOURCE: GE Profile wpre6100gowt, wont agitate or spin
same problem
Posted on Sep 06, 2009
  • 1531 Answers
SOURCE: GE front load washer wont start model #WHDVH626FWW
there is a chance that your door lock has failed
Posted on Feb 06, 2010
Washer stoped flashing code f21
you have something stuck in the pump or a bad pump,remove the bottom cover,look at the pump and you'll see that the center has a grove in it so you can grab it and turn it counterclockwise to remove it but first with a shop vac vac out all the water in the tub then set up the vac down near the pump,turn the center of the pump until water start to leak out,vac it up until it's drained and then remove the center piece,clean it out,also stick your finger into the pump and feelaround to make sure nothing is in there or in the impellar,check the rubber boot of the hose,you can stick the vac in there to see if anything gets vacced out,put the piece back in tightly,add some water,put it on drain,if it drains you're done,if it doesn't check the pump again,if it's clear you need a new pump,those pumps are hard to kill so most likely your gonna find some lovely stuff in there,also the water stinks from the detergent so get ready for the stink,it's always like that.hope this helps,if your washer doesn't have the pump that the center part can be removed just pull off the hoses and clean out the pump and check the hoses for any junk cought up in there.good luck with your washer
Oct 19, 2011 | Kenmore Elite 45986 Front Load Washer
Where is the pump filter on a front loading ge washing machine Model # WCVH6260FWW
The filter (or clean out trap) is located on the drain pump. To access, just follow these steps:
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe.
For reference, you can view some excellent exploded view diagrams of your washer at appliancepartspros.com. If you have any questions about this procedure, please let me know. I hope this helps you.
Oct 27, 2009 | GE WCVH6260FWW
GE front load washer- error msg "door locked"
have you checked for any foreign objects in the drain pump itself this if the most likely problem.or the drain pump has completly stop.make sure you pull the drain hoses from the pump and check for foreign objects if there is still water in the unit use a shop vac and connect it to the drain hose to remove all the water before disconnecting the drain hoses. after the water is drain this may unlock the door as well
Sep 16, 2009 | GE WSXH208A Front Load Washer
Cycles take too longon my GE Adora front load washer; the speed cycle is normally 30 minutes but takes 1.5 hours
It is probably the fill valve filter which is blocked or the drain outlet is obstructed.
You can clean the fill valve filter by turning the water off and disconnecting the hose ot hoses
There is a plastic filter just inside the valve which needs to be kept clean
If you have a slow discharge from the drain pump that also will cause the machine to take a long time on a cycle
Take the discharge hose out of the waste pipe clean the end and get someone with strong lungs to blow down it you should be able to hear air bubbles inside the machine if not then you may have a sock stuck in the pipe from the drum to the pump
Jun 08, 2009 | GE WSXH208A Front Load Washer
WSXH208V1WW front load washer won't drain - faulty pump?
remove lower panel behind panel will be pump after removing as much water as possible in tub remove access port on pump and clean also ckd as far into pump as possible ..pump can be removed and taken apart if necessary ..if pump is clean may be issue with pump impeller they will sometimes break or come loose on motor shaft if impeller free wheels replace pump
Oct 25, 2008 | GE WSXH208A Front Load Washer
My washer will not start!!
Does the start/pause button flash and then the door unlocks? I had that problem too. This is what I did. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 19, 2008 | GE WSXH208A Front Load Washer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Oct 13, 2008 | GE WSXH208A Front Load Washer
Wont spin
Sep 17, 2008 | GE WSXH208A Front Load Washer
Kenmore front loader washer
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Jan 25, 2008 | Washing Machines
Washing Machines Logo
333 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
