I have a hitachi model 51f59j it wont power on and no sound
It wont power on.you hear a small click. and thats it tried turning off for 30 seconds and unpluging the electricial cord but no luck
  • 4 Answers
SOURCE: MY Hitachi 50v500 is shutdown itself
possibly a bad power supply board.
Posted on Oct 26, 2007
ctf1800
  • 4402 Answers
SOURCE: TV makes clicking sound when power cord is plugged in
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 08, 2008
ctf1800
  • 4402 Answers
SOURCE: Hitachi 61UDX10B
[BRAND SPECIFIC][TOSHIBA][QUICK FIXES]
Flashing LED
<< Back to Quick Fixes Page
If your set all of a sudden won't come on, e.g., the screen is blank, but the LED on the under the screen next to the on/off switch keeps flashing, then there may be an internal fault on the set that needs to be reset.
To force the reset, try this:
  • Unplug the set and wait a few seconds
  • Replug and see if the video returns
Whenever the set senses an internal fault through its monitoring circuitry, it essentially shuts down the set. The flashing LED provides the indication that a fault has been detected. Removing power to the set resets the monitoring circuitry. When plugged back in, the circuitry again does a check of the system. If it finds that there truly is a problem, then the set is shut down and the LED will again flash.
Posted on Jan 22, 2008
SOURCE: HELP!!!
I think i have the solution to your problem,
I think that the lamp has gone out in your tv. You should try changing it out. I work with many tv's with DLP's and it almost always is the lamp. YOu can order it online, there is a slot on the side of the tv were you can change it out through there, the lamp should have a number on it. And its pretty simple to do. So there you go..and I could have gotten you a better deal on your Tv.
THE END
Posted on Nov 21, 2008
  • 11 Answers
SOURCE: acer laptop wont turn on has power button light up
This is a common problem with Acer units, both desktop and laptop. The motherboard fails to read the system BIOS at startup. Removing the battery from a laptop merely removes the power source, but not the stored memory. If you are able to locate the CMOS battery, or the cell battery the size of a US quarter dollar, that is the system battery. Remove that, wipe with a lint free cloth (coffee filter) then replace.
If that effort fails upon replacing the cleaned CMOS battery and laptop eneregy source, then a new coin cell may be the solution.
If a new coin cell fails to resolve the problem, the motherboard itself is the culprit. Time for a new laptop or desktop.
Hope this helps you...
Posted on Dec 29, 2008
Hitachi 46w500 went off tonight during storms, low voltage, wont turn back on
There might be a failure on the power supply or horizontal section of the TV even if you see some light inside the TV. Some of the voltages could be missing and that is why the TV fails to power up.
If you know how to use a multimeter, you could check all the fuses from your power supply.
Unplug your TV from the main AC line if you intend to do it yourself.
You will know how much you can do or it might safer to contact a tech.
Let me know if you need further assistance
Jun 04, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Hitachi Model #51f59J The TV will turn on were it
http://gethuman.com/phone-number/Hitachi
Aug 13, 2010 | Hitachi 51F59 51" HDTV Projection...
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a sharp-aquos flat screen tv model#LC-37GB5U and my problem is it turns itself off and then wont come back on.yesterday it worked perfectly,today it wont even turn on.when i push the power button...
Power supply board it dead.Replaced the power supply board should solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board. .
Jan 20, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hitachi model 51f59j no picture no sound
YOU HAVE POWER BORAD PROB CALL PTS AND BAY THERE BORAD COMPLETE 8128249331
Dec 29, 2008 | Hitachi 51F59 51" HDTV Projection...
Power keeps surging and won't stay on
I will need the model number of your set in order to make any suggestions as to what possibly could be causeing the problem
May 17, 2008 | Hitachi Televison & Video
Hitachi 46ex3bc
I have the same problem with mine. i,m pretty sure that it is the built in surge protector is bad. Try unplugging the tv for 30 seconds then plug it back in and turn it on. If your surge protector has not completely gone bad this might work a few times. mine won't turn on at all anymore.
Nov 24, 2006 | Hitachi 46BX01B 46" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
