Question about Kenmore Washing Machines
Looks to be black substance under washer spun onto floor maybe oil
IF THE SUBSTANCE IS BLACK POWDER YOU MAY HAVE TO CHANGE THE CARBON BRUSHES ON THE MOTER
Posted on Nov 01, 2012
SolutionGuy
  • 331 Answers
SOURCE: Oil/Grease under washer machine
Nash, your unit appears to be made by Whirlpool. (Kenmore doesn't manufacture anything, they purchase from major manufacturers and put the "kenmore" name on them) If, as I suspect, it is made by Whirlpool... the top transmission seal is failed allowing small amounts of water to enter the tranny. The water, being heavier than oil, will displace the oil through the top of the tranny... out through a "weep" hole. The weep hole is not designed to allow fluid to escape, it's designed to allow air to enter and exit the transmission housing, compensating for the heat expansion and contraction of the lubricant that should be contained within. Regardless of the manufacturer, you have a main drive system failure on your hands. It'll only get worse from here. Most manufacturers put a 5 year warranty on their drive-trains, you should call them immediately. If it's over 5 years old, it's a very expensive repair.
Posted on Sep 01, 2007
  • 262 Answers
SOURCE: GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Posted on Dec 29, 2007
  • 185 Answers
SOURCE: Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Posted on Mar 26, 2008
SOURCE: Oil on floor under washer
Thank tou very much you were of great help.
Posted on Mar 27, 2008
  • 94 Answers
SOURCE: Oil spill under washing machine
Sorry, this could be bad. The transmission might have blown a seal. It's a big job to fix, if this is the problem. It might be time to consider replacing the machine.
Premmy
Posted on Oct 21, 2008
Bosch fridge freezer: Oil substance- like corn oil/ olive oil - puddle of this appearing on floor under freezer section. cannot find any source for this. Is it likely to be a leak from the black tank unit...
The oil like substance could be coolant, but it could be something else. If the compressor has developed a leak you won't have that long before it goes, and you will notice the compressor getting hotter and hotter before it just totally locks up.
BUT are you sure that the oil like substance is coming from the compressor and not the coolant line? If it is the coolant line that can be repaired and the unit charged with coolant as long as the compressor hasn't locked up due to low coolant. SO I would attempt to localize the leak the best you can.
Jan 07, 2012 | Refrigerators
Washer wont spin & drain all the time...
sounds to me like you need to replace the timer if you can get it to work by clicking the knob sometimes. i have had washers that have had that oil smell too but it was on an older unit and the motor was actually slinging oil onto the floor. you may have two unrelated issues.
Nov 06, 2009 | Washing Machines
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
I have a Maytag Atlantis MAVT754EWW machine and there is a black soot like substance being left on the floor under the washer. It smells like rubber - do I need to replace the belt and if so, how do I do...
this black soot like substance is the motor carbon brush dust. i would get the motor brushes replaced and clean off all the dust from the pulleys and also replace the belt as it has been slipping on the dust.
Mar 18, 2009 | Hotpoint Aquarius WMA52 Front Load Washer
Transmission noise
Washers normally don't have much grease in them at all....the transmission is full of oil....which on GE washers often gets dumped onto the floor.Remove power, tilt the washer back and check on/around/near the large center pulley under the tranny....often the belt and pulley throw the oil around inside the cabinet.
Some of the oils they use are a synthetic oil....acts a little diff than some other oils....sometimes if water gets into the tranny the oil can change foamy or black due to the moisture.
Feb 10, 2009 | GE WHRE5260E Top Load Washer
Premmy
Oct 21, 2008 | Washing Machines
Oil and black specks on floor underneath washer (middle)
Check the position of the oil mark and check your machine to find out which place was leaking and fix it, maybe you need tie the screw up a little bit.
Jul 21, 2008 | GE WBSR3140DW Top Load Washer
NO SPIN
Normally on a top loader such as yours, these symptoms are an indication of a broken motor coupling. The coupling is located just behind the drive motor and couples to the gearcase (or transmission). The oil you mentioned may be coming from the gearcase. They can leak at times. This may be a sign the gearcase is beginning to fail, or....maybe not. I would clean up the oil and replace the motor coupling, first. Click on the following link for step-by-step instructions:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
If you need assistance in locating parts, please post back with your COMPLETE model number (located along the wash tub opening under the lid), and I can provide that information for you.
When you disassemble the washer, a tell-tale sign of gearcase failure will be signs of oil spray marks on the interior cabinet walls. If the washer has gotten to this stage, it may be a good idea to replace the gearcase as well. If the only indication you have is a few oil spills on the floor, try running the washer for a while with a piece of cardboard under the gearcase to see if the problem persists. The reason I suggest this is because I have seen signs of leakage in these gearcases before, cleaned up the spill and never had another problem. Its much easier to replace the coupling first. I hope this information is helpful to you. Let me know how things go, and if you need further assistance.
Jul 07, 2008 | Kenmore 22422 Top Load Washer
Mar 22, 2008 | GE WNSE5260D Top Load Washer
Washing Machines Logo
292 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
