Question about Hitachi Televison & Video
I have a hitachi ultra vision tv and had alot of blue dots a then stop working
Had dots for 2 weeks then stoped working
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
A lot of blue (or any color) dots suggests a optical issue---depends on model number.
Posted on Nov 01, 2012
Slinteriors
  • 8617 Answers
SOURCE: 61 Hitachi Ultra Vision has double image
you will need to replace both convergence ICs they are STK392-110 you will also need six resistors (2) 2.2 ohm 1watt
(2) 1.5 ohm 1watt, (1) 3.3 ohm 1watt and (1) 1.8 ohm 1watt.
You can get replacemnet ICs and resistors at te following link with free instalation instructions. Here is the link.
http://servicemanuals.vstore.ca/
Posted on Jul 17, 2008
ladywinn
  • 5138 Answers
SOURCE: hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Posted on Dec 25, 2008
freetek
  • 5568 Answers
SOURCE: Hitachi Ultra Vision 61UWX10BB Will not power up Red led flashes
Your repair didn't address the failure. It is much more likely (in the absence of video and sound) that the power supply has failed.
The items you replaced affect convergence and have nothing to do with the audio section or the set's ability to receive signal. The power supply failure will diasable everything.
Look for a separate board with larger-than-average components, some cylindrical (capacitors), some block-shaped (chokes and transformers). And you may be able to recognize its relationship to the AC input line.
Locate the assembly number which may be on a paper label or just printed in ink on the board; any that appear to have been part of the etched traces will be only the empty board number, not the assembly.
Removing and replacing this assembly can be done by most everyone using a little common sense and just plugging in the connectors where they belong. Call your Hitachi service center and ask about potential repair or replacement costs. If you can score a new board, don't throw away the old one since the new board will be as crappy as the original. This way, you will have time and opportunity to find an independent reapir service for these and have a spare on hand for . . . sorry, the next failure. These things aren't 'your father's TV', they die much more often.
Posted on May 25, 2009
  • 126 Answers
SOURCE: blue dots center and yellow stain right hand corner on 60'' sonytv
Yes, I do. It needs a new light engine. Very costly repair. However, Sony has extended the warranty on many of these LED projector sets. You need to call a local Sony authorized service center and see if your model is covered. Otherwise this repair could run over a thousand bucks.
Posted on Jun 14, 2009
  • 143 Answers
SOURCE: Viore 50 tv has white dots
bad pixels
Posted on Aug 13, 2009
When installing new lamp, should ballast be replcaed also?
Is there any noise coming from the cable box? My TV had similar problems, and when I had Comcast change the faulty box, the problem stoped
Jul 02, 2014 | Mitsubishi WD-62327 62" Rear Projection...
My horn stoped working, when I press the horn I only hear a click.
There was a recall done on those vehicles in 2008 for the same issues. Something about a clock spring. If the recall work has not been done on your SUV, bring it to a dealer.
Apr 12, 2014 | 1999 Ford Expedition
Dot in the center of my lcd modnitor
You may have a bad pixel, unplug and disconnect video cable, now press and hold power for 2 minutes. Now plug everything back in place and start monitor, is dot is gone ? if yes! there was a static charge that caused the dot to appear, but if there was no change! you have a dead pixel no remedy.
Apr 05, 2012 | E-Machines eMachines Monitor E15T4
My fridge has stoped cooling frezzer stoped last week dumped the ice out move frome wall started working agin for a week than stoped working yesterday WTF is was made in 06 is the compressure out or what...
you moved the fridge out from the wall and it started running again?try opening the fridge door and tap on the fridge control and see if it starts up.i,ve gone into houses and then the woman tells me when the fridge shuts down she hits the side and it runs again.it's the control,this could be your problem also,when you moved the fridge the control could have kicked back on.let me know what you find
Jan 13, 2011 | Frigidaire FRS-26DR7D Side by Side...
RCA F20518WN 19" tv
Sorry, I am not sure..this is not really my area of expertise. You would probably want to get in touch with Bestdarngood
He'd probably be able to assist you better. Please do not rate this post, as I was unable to provide you with a solution..
May 19, 2008 | Televison & Video
No picture, just grey dots
try contacting xbox they'll know what to do
Sep 04, 2007 | Microsoft Xbox 360 Console
Televison & Video Logo
149 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
