Question about JVC TH-M303 System
How to connect dvd to sub woofers
  • Anonymous Jan 06, 2009
    i have not yet used it.
    i did not know how to connect dvd with woofer i have no cable to connect tell me how to connect woofer system with dvd
  • geek0 May 11, 2010
    How do you get sound in your system now?
You need the sytem cable that goes with the system--see if your mate still has it 'cos they cost about £23 to replace
Posted on Mar 17, 2009
Th-m303 sub dont sound when playing dvd
Please try and connect the DVD using the coaxial or the optic cable so that the input is seperated to perrform on the amplifier with a true DTS.
Oct 26, 2011 | JVC TH-M303 System
Sub would only sound when am listening to radio would not sound when playing dud aux but surround speakers play
Possible that the connection to the AUX does not activate if you are using RCA inputs. Connect the DVD using the optical cable or the coaxial link and it must play better with surround and subwoofer in DTS.
Sub dont play when in dvd mode
it could be the setting you are in sometimes there is different settings when you are i different modes just go in and change them and you will be fine and it should work just look at the manual and follow it
Mar 31, 2011 | JVC TH-M303 System
JVC TH-303 woofer suddenlty not working, what to do?
Check the fuse on the back panel or possibly inside the enclosure then if blown just replace with another one will cost about $1.00
May 18, 2009 | JVC TH-M303 System
Jvc th-m303 sub woofer not working all other speakers are fine
check your internal wires inside subwoofer.b4 that try to connect to other instrument to make sure it not working.
May 12, 2009 | JVC TH-M303 System
Need a cable
radio shack near you.
Apr 06, 2008 | JVC TH-M303 System
often your sub need to be change because of its malefunction.
Mar 09, 2008 | JVC TH-M303 System
No sound
please check cables between dvd and subwoofer.test with good new or working cables.
Jan 20, 2008 | JVC TH-M303 System
Well this is and isn't a fix. I don't know what the underlaying problem is that causes the Amp to shut down but I have come up with a way to stop it from doing so. What ever the problem is it is triggering a circut on the board called "Protect" which can be circumvented. You need to start by pulling out the amplifier unit from the subwoofer assembly. You will see that there are two circut boards at 90 degrees to each other that are connected by 3 sets of connectors. You need to remove the screws and wire that hold in the board attached to the bottom of the assembly. You can then pull it out disconnecting the connectors. The connector closest to the power trasformer is the one that we are concerned with. On the vertically oriented circut board you will find a small map of the connector identifying pin #5 as "Protect". Inside the portion of the connector attached to the bottom board that you pulled out, use a small set of needle nose pliers to break off pin #5. Then reassemble the amp and put the subwoofer back together. I used this solution and it has been working since. If you have reservations about breaking the pin out then try just bending it out of the way and partially reassembling the unit and powering it up. Once you see that it does indeed solve the problem you can break it out. Like I said, I don't know why it started to turn off spontaniously in the first place but this does fix the problem.
Dec 19, 2006 | JVC TH-M303 System
JVC TH-M303 System Logo
154 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
