Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Ice maker not making ice
Sears elite side by side freezer just stopped making ice.
  • faysmother Jan 04, 2009
    yes it still dispenses water, and what ice is left, through the door.
  • neilellis May 11, 2010
    is it still dispensing water through the door
  • 37 Answers
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Posted on Jan 05, 2009
2 Suggested Answers
farfield
  • 462 Answers
SOURCE: Kenmore Elite side-by-side refrigertor
depends on the problem.
1st what is the freezer temperature by the ice maker?
Is it filling with water?
Does the water freeze solid?
I fthe temp is below say 12'f and its filling with water a replacement kit of just the head of the icemaker should fix you up. Some kits though have instructions you need to read befroe proceeding., Some of the instructions may not be clear so read them where you buy the replacement and ask questions there as to what to look for.
If this helped you pleaese rate me as much as you can. If it did not help you please restate your question so I may give more detail to communicate to you better. Thank you and good luck.
Posted on Mar 21, 2009
Ice maker stop taking water Kenmore
check plastic tube that runs from rear of the freezer. See if it is pluged with ice. If you find it is change the fill valve at the back of freezer behind the compressor cover. It could be a double valve, as one part.
Oct 13, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore side by side ice maker sprays water into freezer
Is it actually spraying out of the icemaker or is it running down the back of the freezer?
Jan 31, 2013 | Kenmore Elite Sears & Other Brands...
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our Kenmore Elite (new last summer) bottom freezer double top doors, stopped making ice. The wire that seemingly controls the ice maker is hanging down in a way that is causing difficulty opening the...
Well, that wire is likely the cause of your issue, somebody probably bent it, and now it gets caught on the door or a basket or a food item or what have you, and since it cannot move, the ice maker will not make ice.
Aug 13, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Refer Internal leak
Hi, look and make sure the inlet tube to the icemaker is inside the fill cup. Make sure there is no ice build up in the fill tube also.
I hope this helps some, please let me know if I can help further.
Thanks Vic
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mar 21, 2009 | Kenmore Refrigerators
Kenmore Elite SS Bottom draw freezer refrigator is a lemon
Hi!!! you have to change your freezer fan and bi-metal which are upgraded good luck..call manufacture and see if you have a service flash and covered under warranty..good luckk...
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
