Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Where do i find the drain on kenmore model#1687581?
The dishwashrd is full of water.
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Model 795.71013.010 drip pan is full and leaking onto floor
Those models have problems with the defrost drain and defrost drain tube becoming blocked. Have you noticed water buildup on the floor of the freezer? See item 105A that is the drain tube.
http://c.searspartsdirect.com/lis_png/PLDM/F1002002-00002.png
That drain may have come unblocked because the refrigerator was off long enough for this ice to completely melt overflowing the ice trough seen in the video.
Appliance 911 Sea Breeze
Sep 13, 2015 | Kenmore Refrigerators
Machine stops during wash cycle full of water
object stuck in pump, drain water remove and clean pump re start
Dec 09, 2013 | Washing Machines
Kenmore elite washer won't drain
What is the model number of your washer? This condition is caused by a bad lid switch.
Aug 13, 2012 | Kenmore Washing Machines
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
Jun 27, 2011 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Washer won't drain completely
The balance sensor may be faulty - not allowing full RPM to draw the water out.
Check it/ replace it as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 27, 2009 | Kenmore Washing Machines
Dishwashers Logo
55 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
