Question about Welding Tools
GMC-arc welder cuts off regularly, after only 10 to 15 flashes
Take rod sizes 1.6 to 3.2 but using size 2 rods at the correct set up, still cutting off too regularly-under a minute. Before this problem, a relative used it at the maximum set up using size 3 rod. I wonder if this is the cause to this problem. Also wonder if tere is an over heat fuse to change, a reset button to press or any other internal problem inside cover to be fixed? as it appears, no other outside switch apart from the on/off and ampere setting.
  • 92 Answers
Sounds like an earth leakage on the transformer AC set ,or a bad joint on the circuit board on DC. if the power output is forced above its rated duty cycle then the heat gnerated can cause all sorts of problems on the circuit card/s, this intermittent on off syndrome tends to indicate a bad joint, but the problem is where, you would be better getting your local welding distributor to have it checked out, be careful because they will probably charge you for stripping it down then, if the set is goosed, you will get the set back in bits, weigh the cost of repair against a new unit and charge it to your relative.?
Posted on Jan 23, 2009
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
What do I set the welder at if I am welding with
Depends on what size electrode you are using. 1/8 @ 110 amps
Oct 07, 2014 | Welding Tools
I just bought 15 cans unopened of atom 8018 c-1 What is it good for? Should I try to sell it? Thanks
#1: Atom arc rod is very good and expensive rod comparatively speaking. 8018 is similar to 7018. It is an all position rod but instead of 70,000 pound tensile strength , it has 80,000 pound tensile strength.7018 is commonly used in repairs or steel construction 8018 is used in appilcations where the need for a higher strength or stronger weld is called for . Usually when welding higher grade steel than A.-36 It can be used in place of 7018. 5/32 calls for 150+ amps. 1/8 is a more common size.Remember Atom arc is top of line but finding someone who will pay the difference or needs this rod may be hard to find.
Mar 03, 2011 | ARC Atom Arc 8018 532" Welding Rods 38 Lb...
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
1 push rod is steel & 1 is alum, which one is exaust?
The intake valve is the lower valve and its push rod is the aluminum one, the exhaust is the upper valve and it has the steel rod, there is no rocket science going on here, the aluminum push rod is used to cut costs.
Apr 29, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Have a 120 volt 70 amp stick welder what gauge or stick type do i use
1/16th stick to 3/32nd.
3/32nd being the maximum. Don't use 3/32 for an extended period of time, or you can burn up that welder. (Even if it has a fan. If it doesn't have a fan built-in, I invite you to put a house box fan, close to the ventilation slots for the welder)
I would also recommend using 6011 rod. It's a mild steel rod, and is excellent to begin with. Usually used for filling, and medium strength situations. It does splatter, be aware of that.
Not trying to give you a tutorial on beginning welding, but would like to offer some tips:
1.Make sure the ground clamp has a good, clean surface it's clamped to. If not, it will be very hard to get the rod started, and also to keep it going. (Makes bad welds too)
2.Start with a B U T T weld. (Had to type it that way do to censorship of certain words)
That's laying two pieces of metal next to each other, and laying a bead in-between them. Easiest thing to start with. Go to corner welds next, (Two pieces together at a 90 degree angle), then try Uphill welds.
3.Shield flipped up on helmet, welder on. Lay the rod past the area you are going to start on. Past the metal edge. Lay the ->flux coating of the rod on the edge of the metal piece. The tip of the rod is past the metal edge by at least two inches.
This way you are lined up to begin the weld. Then flip your shield down, draw the rod back, until the tip of the rod touches the metal. Once the arc starts, lift the rod up a little to get the correct height, and keep that arc going.
4.Watch the PUDDLE, not the arc! You are watching the melted metal in front of the arc. You need to see how that puddle is doing, in order to compensate by bringing the rod closer, or further away.
5.Use a Zig-Zag pattern to begin with. Keep the Zig-Zag close to each other, until you are comfortable enough to make a longer pattern. Watch the penetration. Good penetration is the key, not a pretty weld.
6.Use the proper safety equipment. If the welding helmet lens has a tiny little scratch, you will burn your eyes. NO fun, believe me!
You won't know it until you wake up the next day with your eyes swelled shut!
Cover your arms, and use welding gloves. Welders give can give you a radiation burn, worse than a bad sunburn. NEVER just start welding a little with No welding helmet. Welding goggles are for the birds, or Acetylene welding!
Be safe, have fun welding!
Sep 02, 2009 | Welding Tools
I have old welder hobart tdu-292 irun 6010 1/8 rod when i wip and pause the arc goes out. i try going up on heat still the same problem
if it's an AC welder try using 6011 0r 6013. The best rod to use on AC is odd number rod and on DC even
May 03, 2009 | Welding Tools
We need a longer down rod for our Outdoorsman ceiling fan and haven't been able to find the right size rod. Do you know where we can find it?
If you know the size hole 1/2" or 3/4" you can go to Home Depot or your local hardware and have them cut and thread you the exact length you need.
Apr 10, 2009 | Dryers
Welding Tools Logo
80 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
