Question about Maytag Atlantis MDE6400AY Electric Dryer
When you turn on the dryer you have to hold the button and it will run but if you let go of the button it stops working. then other times it will not work if you push the button.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You will need to change the door switch. Here is the part you need.
Posted on Nov 01, 2012
2 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: Maytag PYE2300AYW starts when I hold the button in, but will not stay started.
The motor will need to be replaced. There is a throw-out switch on the motor that keeps it running after you release the start button. These are generally easy to change, with the only hard part being taking the cover off and putting it back on. http://www.partstore.com/GetModel.aspx?MfgName=Maytag&BrandName=Maytag&ModelNumber=PYE2300ayw&PartCategoryName=&Keywords=motor Any of these motors listed will fit your unit.
Posted on Sep 17, 2007
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
My electric dry button wont keep it on. if I hold it it runs. but the min I take my figure off the button it stops working. the model is an elite
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 04, 2011 | Dryers
Turned on Dryer today; problem; Estimated time remaining window shows CL (no time) Non of the time buttons selected show time in window. Dryer runs forever; gets hot and drys clothes. Pause button does...
The Child Lock feature is activated and it can be deactivated by pressing and holding the DRY LEVEL button for 3 seconds or until the CL display is cleared.
Indicate the exact model number of the dryer if the control panel doesn't look like the one shown above or if no button with the small "PRESS & HOLD 3 SEC TO SET CHILD LOCK" (DRY LEVEL) marking is found.
Mar 06, 2011 | LG DLE2514 Electric Dryer
Start button and no heat
Those two problems are usually unrelated and I believe you just have a coincidence that they both happened at the same time. You should replace the start button since it is faulty. The heating problem could merely be that the machine does not have enough time running to heat up since you have to hold the button to keep it running, however if that is not the case then you should replace the heating element and the thermostat. Possibly the thermal fuse as well just in case.
Dec 24, 2009 | Dryers
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Kenmore dryer start button not working
when I push the start button on my kenmore dryer it will not start and the drum will not turn.
Nov 09, 2008 | Dryers
My Dryer will only work if I hold start button, when I release start button the dryer stops.
Anra, this is a classic symptom of a failed even heat board. I've seen a lot of these failures out there. Easy to change out. Check out this link. Catriver..post back http://www.repairclinic.com/0080.asp
Mar 26, 2007 | Whirlpool GEW9878LW Electric Dryer
My Dryer will only work if I hold start button, when start button is released the dryer stops working.
Anra, the problem is in the even heat board under the consol. This is a very easy job. Check out this link. Catriver, post back http://www.repairclinic.com/0080.asp
Maytag Atlantis MDE6400AY Electric Dryer Logo
149 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
