Question about Samsung LN Computers & Internet
E176FPf Dell monitor stands only. I Have 48 monitors without stands or connection cables and yesterday I posted that I need up to 48 stands only but I need both parts. I need any or all of both or either. You can email me at rickzerah@gmail.com with any help you might have. Thanks
  • 198 Answers
SOURCE: Hooking the monitor/computer to cable
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
SOURCE: Dell E153FP monitor
I have a Dell E173FP LCD, my monitor don't want to stop showing his Main menu , I had the problem since 3 months and didn't get a solution for it , some time it keeps showing the main Menu without stoping ,sometime not...crazy monitor.... But i have a friend that faced same prob and toldme to open the it and see inside it if there is a detached cable or anything...just don't know how to..please tell us a soultion.
Posted on Sep 06, 2008
  • 62 Answers
SOURCE: unlock Samsung SyncMaster 551 15" CRT Monitor Problem
1. press the menu switch 15 to 20 secunds ,
Posted on Nov 03, 2008
aouate3
  • 123 Answers
SOURCE: Power-Supply Plug in on Monitor not present ?
wait, is there not a power port? if ther isnt, it may be on the vga port where it connects to the pc, it may of got cut off, your alternative is opening up the mointer and wireing a new power port
Posted on Aug 27, 2009
Testimonial: "I posted this question back on 08-27-09 Finally got the right solution. I had never seen a Plug-in for the power-adapter on the Vga-plug itself. Thank"
  • 11800 Answers
SOURCE: i have a samsung 17''
The message says that the monitor doesn't receives signal - which is normal. Since the problem appears only after you plug in the cable in means that the problem is located there - something is wrong with your pc, most likely the video card has died.
Posted on Oct 03, 2010
WHAT DELL e176FPf ERROR START WITH A TEST COLOR?
Dear Anonymous,
This seems to be normal. When a monitor is not connected to a VGA or other source, it goes to test mode in some configuration. But if you can find the menu, setting or configuration button, there is a way to configure not to go to test mode. On my monitor there are only 4 buttons. But they are labled Menu, <>, Return.
The configuration for the modes is under monitor setting. This could vary from monitor to monitor. You should explore your equipment with a little help of noting down your way. The way I do is a notepad and pencil. I note down my action and follow back my steps if my requirement is not met or I did something very wrong.
Best of luck and let me know us know your results. This could help others with there troubles :).
Regards
May 19, 2014 | Dell Computers & Internet
Today I received a faulty Monitor Dell E773c, the problem is that the Monitor get On and the power LED is Green and after remove VGA Cable from CPU it get Orange, But no Display (The Screen is Blank)
To get monitor work for you, you should connect the VGA cable to CPU. When you remove the VGA cable, monitor has got nothing to display so it goes in stand by mode with orange LED on.
Sep 15, 2013 | Dell Computers & Internet
What kind of cables are needed for my monitor?
Hello
Use the 15 hole socket by connecting a VGA cable. Thie cable can be boutght from most of the electronics spare part selling shops.
Feb 04, 2012 | Dell 1800FP Monitor
Dell monitor power on and power light goes on and off
First place to look will be the power supply caps, look for caps with bulging top, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
http://www.lcdrepair.us/e176-177fpc-inverter-power.html
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
http://www.lcdrepair.us/e176-177fpm-inverter-power.html
Feb 16, 2010 | Dell E176FP 17" LCD Monitor
Problem w/Dell E176FPf monitor stuck in power save mode
Ok if it the monitor works fine on another unit discount it out of the equation as a monitor problem.
I would suspect the driver on the PC that delivers the problem, especially the video card.
. Check that the cable is also on tightly. remove it and even clean the pins and replug it .the plug on that PC may be dirty
You May need to replace the video card as the communication to the monitor is intermittent and that is why you get the amber light.
Open the box with power off. clean the card if it has a lot of dust on it ( most do and its always a shock) wipe it over ( BOTH SIDES) and then try to start it up as usual with the monitor connected to see if that fixed it ( sometimes works) if not get another card and replace it. Best I can offer without being there to help on the spot.
A new card should allow you access to install and configure it and these days they are pretty cheap to buy
Please rate this help to keep the service online
Aug 20, 2009 | Dell E153FP 15" LCD Monitor
Dell monitor not working
just try running the Test on the monitor(monitor self test) ie disconnecting the video cable of the monitor & leaving the power cable connected & then see if u r getting the red,blue,green multicoloured bard moving on the screen or not,if yes then the monitor is fine otherwise the monitor is bad.
Apr 02, 2009 | Dell Dimension 8400 PC Desktop
Dell 410XPs + Dell 3007WFP monitor issues
Vinod,
That's quite strange as during system startup you should see the Dell POST logo as at that point the card is only running at VGA, and the monitor will support display at this resolution. If you connect with a normal single DVI cable the monitor should display at 1280x800 also.
Have you tried this? Also have you had this monitor working on another computer at all? What happens if you power up the 3007 with no video cable connected? It should cycle through the pixel test screens. If you are not getting that, and you are not getting the pre POST logo during powerup i suspect that it is a screen failure.
Aug 03, 2008 | Dell Dimension XPS PC Desktop
Monitor in Power Save Mode
The inverter power logic is probably going bad. You can get it here as well as look at instructional videos on DELL monitors.
May 04, 2008 | Dell E176FP 17" LCD Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Dead, Dell E176FPf
If it is still inside the three year monitor warranty period I would recommend calling tech support to have it replaced. Larry Dell Customer Advocate
Apr 16, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
27 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
