Question about HP Officejet 5610 All-In-One InkJet Printer
Hp 5610 not responding
My clerk had a paperjam that I was able to correct this afternoon, since the paperjam my printer is not responding
  • HP Master
  • 685 Answers
Try turning it off and back on. if that doesn''t work then try to unplug it for a couple minuets and plug it back in
Posted on Jan 04, 2009
Am a service person i hav an office jet 5610 printer it always giving paper jam error what is reson for that
very often you get paper clips or staples that block paper path and therefore causes paper jam. also, some paper path sensors gets damaged and the debris can cause paperjam. I suggest you open all levers and check for foreign matters. You can even put the printer upside down so that the foreign thing gets out. The next step is to dsmantle everything and remove the fault.
Jun 08, 2010 | HP Officejet 5610 All-In-One InkJet...
My hp officejet 5610 is not responding to the printing option it once did now it just gives a scanning option and dusnt scan. what do i do
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
abdsf26777
Aug 03, 2009 | HP Officejet 5610 All-In-One InkJet...
PaperJam
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
ab18
Jul 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Printer not responding all though active as
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Thanks, GF
Apr 27, 2009 | HP Officejet 5610 All-In-One InkJet...
My hp printer 5610 all-in-one does not turn on. What to do?
whenever i press the 'on' button, my printer doesn't respond.
Jan 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Set up HP 5610 to fax lost manual
I just bought an HP 5610 series all in one fax, copier and scanner. How do I set up the fax machine?
Sep 06, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
64 people viewed this question
Ben Johnson
