Question about HP Officejet J5780 All-In-One InkJet Printer
Power supply Had a power outage and cannot turn the printer on since. Any ideas>???
  • HP Master
  • 685 Answers
Have u tried to unplug it and leave it unplugged for a while?that is the first thing i would do.if that doesn't work let me know and we will try a couple things.also please tell what kind of printer.thank you
Posted on Jan 04, 2009
Power is on but the printer display won't turn on.
unplug the printer power supply for about 10 seconds, the plug back on, i have to do that to my wifes printer ever so often, most usually right after a power outage.
Mar 17, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
I have a Canon Pixma ip90V printer and every time the printer starts to print it shuts off; any suggestions what to do?
Sounds like it is either the power supply or the board.
Try disconnecting the power supply (unplug the printer) for about 5 minutes. Reconnect and turn it on. If this works it will probably not be a long term fix. Sounds like your in for a new printer or power supply for it soon. Did you have a electric outage recently? Or power surge?
Mar 28, 2011 | Canon PIXMA iP90v Printer
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
Printer won't turn on. had power outage yesterday. now printer won't turn back on. have power to receptacle.
Sounds like a bad low voltage power supply.
You can google a business called The Parts Drop and contact them.
Dec 08, 2009 | Xerox WorkCentre M15i Laser Printer
Will not turn on. after a power outage.
HI. this will happen during most outages. there is a fuse located inside the power supply device that is used to power your unit. simply remove the cover off the power supply box, and replace the fuse inside. this will correct the issue.
***((Now, if the fuse is OK, and not harmed, this will confirm that the power supply has failed. It should be replaced in this case))
Sep 09, 2009 | Nintendo Wii Console
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
No power
I have two of these where I work and have seen this problem occur after power outages. I've been able to resolve it by unplugging the power and usb cable and letting it sit for 10-15 minutes . Plug everything back up and it works again (until the next power outage)
Jul 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Power outage=shut down
You do not say your location- so this may not be relevant to you. If in UK - check the power cord fuse. If it is a model that relies on an external power supply- try to find anther of the same specification. Other than that presume it has died
Jul 09, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
HP Officejet J5780 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
