Question about Altec Lansing ATP 3W Computer Speakers
WOOFER SOUNDING BAD ON CERTAIN BASS FREQUENCIES
Hi! I own an ALTEC LANSING ATP3 2.1 speaker system. it works gr8 but recently its woofer has started behaving abruptly as it gives wierd sounding thumps(Bass) that earlier used to be like they shud be.i cannot listen to hiphop music! plz. help me out on fixing this problem!
    Genius:
  • 2,985 Answers
Try a software solution- download an audie editor like Audacity. The fault sound like a malfunction in the speaker unit ,which is not servicable.
Posted on May 17, 2007
Sub woofer far too basey relative to treble- appears to have no means of adjustment
You can adjust the bass (and treble) of all sounds coming from the program you are using. For example: WinAmp; Click View -> Equalizer and adjustments can be made from there. I believe the lower frequencies (your bass) starts on the left and continues to get more treble and less bass the higher the frequency gets (farther to the right).
But most programs should have some form of an equalizer. Which can be accessed slightly differently in all of them.
Without more specific knowledge on this one it is hard to give more detailed instructions on this. If need please let me know and I will follow up with a how-to for your operating system and/or specific program you are using.
Jun 08, 2011 | Altec Lansing 221 Computer Speakers
The transformer of my sub-woofer is burnt. When i take it to the repair shop, they say that the transformer is not available. I badly need to fix the speaker as i love them very much and the new ones are...
Sub woofers have small amplifiers , not transformers. The amplifier is removable and replaceable. The The overall size and the output wattage are the spec's you need . The output wattage is on the label which is attached somewhere on the speaker. You do NOT need to replace the amp with the Altec Lansing brand. Have you contacted Altec Lansing to purchase a replacement Amp? That's where I would start. If they cannot help you I would Google replacement amp sub-woofer, Altec Lansing model MX5021.
good luck
Apr 15, 2011 | Altec Lansing MX5021 System
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
Altec lansing multimedia speaker model ATP3 woffer is giving tearing sound at high base and it seems the woofer is not working at all
Your woofer is bad, probraly blew the megnatic coils, and if mention that it's giving you a tearing sound, then the woofer cone is tear somewhere and is not get the reflex to produce the sound.
Jan 28, 2011 | Altec Lansing Multimedia Computer Speakers
Short in subwoofer wire - Altec Lansing computer speakers & sub
yes, you can splice the cables and put on a new connector, goto radio shack with the old connector and im sure they will have one you can splice right onto it. ive done this many times with varios equipment "headphones speakers etc" it may take a couple of tries to get the wiring right but if its just one speaker there will most likely be just 2 wires, if you wire it up and it doesnt quite sound right, wire it the other way. speakers will work wired backwards but wont sound quit right so if it doesnt, rewire it and it should. good luck and i hope this helps!
Jan 15, 2010 | Altec Lansing ADA 885 Computer Speakers
Speakers stop working need to replace don't know where the part suppose to go
Probably the fuse, you need to take out the woofer in order to reach it.
May 27, 2009 | Altec Lansing ATP 3W Computer Speakers
Sub Woofer to Sound Dock
Well if you are talking about the iM600 sounddock from Altec Lansing, the short answer is no. If you want better bass from an IPOD docking system you'll need to buy an expensive component from say Scandyna Dock or you could build one yourself. You would need an integrated amp or a complete system like the NAD C71. This would allow you to plug in a self-powered sub.
Dec 01, 2008 | Apple iPod classic MP3 Player
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Altec Lansing ATP 3W Computer Speakers Logo
239 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
MegaByteMe
MegaByteMe
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
