My thermostat honeywell rth 1108 show me a signal like battery what tht means
The thermostat show me something like a battery flashing what that means
  • 70 Answers
SOURCE: wc wiring on thermostat
sounds like you have a heat pump the w2 on old thermostat is for a second stage heat. If you can give me a little more information on type of system you have (forced air furnace with heat/cool, Heat pump or boiler)? How many wires are on old thermostat? Is it a no programmable or programmable? How old is the furnace?
Posted on Jan 18, 2009
  • 80 Answers
SOURCE: EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Posted on Oct 07, 2009
  • 1015 Answers
SOURCE: Honeywell RTH 221 Programmable Thermostat. Jumper missing
The proper way to do it would be to use a small piece of wire stripped at the ends. Then use a small amount fo solder on each end to connect RC to RH. Or use a small piece of solid(stiff) wire and strip the ends. The wrap the ends around the connector and crimp them to make contact. I would not use a paper clip. A paper clip is not designed to carry 24volt current and could melt.
Posted on Nov 02, 2009
  • 19 Answers
SOURCE: I want to install honeywell RTH 221 thermostat.Thr
If your old stat operated on high voltage ( anything over 24 volts) then the answer is no. However by adding some relays and a transformer you can use that stat.
Posted on Jan 15, 2010
atocrxr
  • 135 Answers
SOURCE: CHANGED BATTERIES AND NO DISPLAY
Electronic thermostats are powered by battery or off of the 24 volt power from the furnace or air handle, or by both. Check and make sure that you have 24 volts from the furnace. If you do have power, then you have a bad thermostat, it make have just gone bad, or got shorted out.
Drop me a line, with more info and I will be happy to help.
Have a great Evening!
Sincerely,
Paul Gibson
Posted on Apr 08, 2010
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Honeywell thermostat rth 1108
First change the batteries. If that does not help, perhaps the user manual will give some hint as to what this means. I hope this helps.
Oct 21, 2013 | Heating & Cooling
Honeywell has made a huge number of thermostats over the years. Directions for each are specific to each model. Your model number will begin with the letters, T, TH, RTH, C, or CT and is on the back of the thermostat.
Once you have the model number, you can obtain the owner & programming information by supplying it on the Honeywell webpage, here.
If you are having trouble, either contact Honeywell directly - or repost here.
May 16, 2013 | Heating & Cooling
Honeywell RTH6350/RTH6450 Thermostats - Have two that had to be replaced as heat would not work at all. Had Honeywell tech on for 1/2 hour he could do nothing from India!! Wondering if these were...
The problem with the honeywell brand is that the only dependable units begin with TH not RTH the RTH is for residential and you can purchase those at a local home improvement store. Go on Ebay and spend the money for a quality t-stat. "you get what you pay for"
Apr 27, 2011 | Honeywell Electronic Programmable...
CHANGED BATTERIES AND NO DISPLAY HONEYWELL RTH 230b
Sincerely,
Paul Gibson
Apr 08, 2010 | Honeywell Programmable Thermostat Heater
I want to install honeywell RTH 221 thermostat.Thr thermostat operate 2 AAA batteries. the thermostat remote the heating system selonoid valfs. They works with 220 volts.My question is can I connect the...
Jan 15, 2010 | Honeywell Programmable Thermostat Heater
Model # RTH 1108 stopped displaying the
is my thermostat( honeywell rth1108) somehow to my attic fan. cant find a off switch for the fan. seems it is controlled by the thermostat.
Nov 29, 2009 | Honeywell Programmable Thermostat Heater
Nov 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Y1 W1 Wire from older Honeywell to new RTH honeywell
Y1 means for cool and W1 means for heat. Connect accordingly.
Aug 11, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
