Have a 5" portable jensen tv/radio - no picture - how to attach a converter?
    Sergeant:
  • 214 Answers
If it's one of the newer models that has the input for an antenna on the back then you can go buy the adapter at radio shack that allows you to hook it up with coaxial with either a converter box or a converter box with an antenna. The attachment looks like a 3.5 audio jack.
Posted on Nov 02, 2012
What converter box do I need for GPX TVP2 5" portable tv?
They all work. If in strong signal area get inexpensive unit.
Feb 04, 2016 | GPX Tvp2- Bk & Wh Tv & Am/fm Radio Battery...
Locked Jensen TV
For anyone who has locked their Jensen TV mistakenly. To unlock it:
1. TV On (Using remote)
2. Press and hold the display button on the remote for about 2 - 3 seconds.
Dec 22, 2007 | Jensen TS2050J 20" TV
Attach tv converter box
Everything is digital now. You will need a digital converter box. You will connect an antenna to it, and then connect the box to your tv. The box will come with it's own remote. Your tv will be set to channel 3 or 4 (depending on the converter box you get), and you will control the stations with the remote that came with the converter. You can get them at any electronics store.
Jan 09, 2014 | Jensen J53-BWR 5 in. Portable Television
Tv monitor
there is a problem inside; take it back and get another one or call jensen and you might have to send it to them for replacement.
Mar 03, 2010 | Jensen J53-BWR 5" Black&White Television...
How to convert the J53 BW to receive digital broadcast signals
Certainly you can use your TV!
The converter box needs an antenna so it can tune the channels, but it doesn't have to be the antenna that's built into the TV. In fact, you'll get better reception if you use an antenna designed for the new DTV broadcasts. Several types are available at stores where they sell TVs, and they start at under $10.
Then you'll need to connect the converter box output to the TV so you can tune it in on channel 3 or 4. I'm not familiar with your Jensen set, but I've never seen a TV without some kind of connector for an external antenna. The most common type on small TV's is a jack similar to an earphone jack. Radio Shack sells an adapter that plugs in and allows you to connect the cable from the converter box. Take the set with you if necessary so you can find what you need.
Feb 08, 2009 | Jensen J53-BWR 5 in. Portable Television
Casio EV 550 B portable TV 3" screen many of "us" with portables are wanting a "FiX" instead of landFILLing our sets when the switchover comes apon us. Is there a DTV FiX? costs? Are there portable DTV's?...
I have my handheld Casio TV-980 up and running with a converter box. All I needed (in addition to the converter box and standard rabbit ears [UHF/VHF] antenna) was an adapter with an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that connects to the TV (RF out) jack on the converter box. The adapter would have been a little cheaper at my local, independent electronics store, but they were sold out.
If your antenna has flat 300 ohm wire connections, you'll need a balun (Radio Shack catalog # 15-1297, about $8) to connect it to the coaxial cable that goes to the Antenna (RF in) jack on the converter box.
I’ve tried 2 different converter boxes with the handheld TV, and they both work well: Insignia (Best Buy’s house brand, same as Zenith) and RCA (from Target, same as Venturer), so any government coupon-eligible converter box should work.
A few other tips:
1. I always turn on the converter box before I turn on the TV. The cpnverter box seems to take control better that way.
2. When I turn on the TV, the tuner doesn’t automatically go to channel 3 or 4 (where it should be set when using a converter box), and the picture quality is poor. If I use the tuner on the TV to get to channel 3 or 4, the picture quality is vastly improved. I have to do that every time I turn on the TV.
3. Placement of the antenna is very important. I like to watch my handheld TV when I'm on the computer, and the reception is better the further away from the computer the antenna is located. I'm actually using a 6' coaxial cable for the antenna, but I could also have used 2 shorter cables with a coupler that has an F jack at both ends (Radio Shack catalog # 278-304, about $3).
If your battery-operated TV does not have an external antenna jack, instructions for connecting it to a converter box can be found at
http://www.digitaltvtrainer.com/national/showme-battery-tv-converter
There are a few battery-operated converter boxes available, but for do-it-yourselfers, this web page also contains instructions for building a 12-volt converter box power supply.
Jan 26, 2009 | Casio TV-980 2.3 in. Handheld Television
The question is, for my small portable Emerson color TV (which seemingly has no external Coaxial cord position), how do I attach a converter box or otherwise assure continued receipt of a signal when the...
AThere is a port on the unit to install an outside anntenna so I'll head to Radio Shck with the set toi get the appropriare item....I hope.  Solution came from ustomer Sewrvice via Telephone though it took a20 minute wait for them to answer.
Dec 30, 2008 | Televison & Video
GE spacesaver 05GP009
I had this same problem, I wanted to use this tv with a converter box and the only way to do this was to hook up the converter box with an external antenna to the small 3.5mm input on the back. If you go to radio Shack and get an "F to 1/8" Adapter"the radio shack part number is "278-257". It worked perfectly. I'm able to get many clear channels, and with the converter box I now have remote control. It works well. Good luck, I hope this helps
Mar 02, 2008 | GE SpaceMaker 05GP009 Television
Jensen TV repair needed
there is a problem with the transistor
Aug 15, 2007 | Jensen J53-BW 5 in. Portable Television
What should I do if I get a picture and no sound?
Can you tell us how the problem started,did you drop the tv?
Sep 03, 2006 | Jensen J50-MCTV Television
Televison & Video Logo
108 people viewed this question
Top Televison & Video Experts
