Question about Drills
What size belts fit toolmac SF2201581 drill press
2 Suggested Answers
SOURCE: replace belt
Sourced the part no and stock number on the Draper site, then sourced the Manual on the Draper site too
Posted on Nov 18, 2009
Hi I have a peerless pedestal drill press model #1516f. I cannot find the replacement belt sizes for the 2 belts? Can anyone help? Cheers Jason
hi jason try going to a car fan belt specialist ,, one that stocks many sizes..take your old ones in to match them with.. as an example search on line as i don't know where you are i can not give more specific info on location.. as an example this web site http://www.totalrubber.com.au/
or try repco car spare parts
Rubber Hose PVC Hose Rubber Matting
i assume your belt is an "A" size
regards pete
Feb 26, 2015 | Drills
GLENTANNER MODEL ZQ116 DRILL PRESS. how do Iknow what size belts are as they are old, cracked and frayed.
Your best bet is to take the old belt with you when you shop for a new one. The sales clerk should be able to match it up.
Nov 26, 2014 | Drills
What is the size of the replacement chuck key for the Duracraft DP514?
The 1/2 inch is the max size drill that will fit into the chuck. There are only a few different key sizes, and sears sells them in their tool area. Easiest thing to do is find the size of the hole the chuck fits into by using the back end of a drill bit that fits the best. Measure that drill bit or take it with you to the store. You might find two different size keys with that size pilot hole, or maybe only one. Good luck!
Dec 27, 2012 | Drills
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
I purchased a secondhand Pentium Metalworker BT1000 drill press, but it came without a chuck key. I haven't been able to find one to fit, as the standard 1/4 inch shank is slightly too large. I think...
if there is any manufacturers name on the chuck like "JACOBS or ROHM" you would also need the chuck size 13mm or something like that, you should be able to go to a BOX store that sells tools and find the correct one. ROHM has a completely different key than other brands. Usually on the key on the back of the packaging it will give you what it fits. I would also suggest taking a drill bit and trying one till it fits snug in the hole and then look for a key with that pilot size. Good luck
Jun 24, 2011 | Drills
Need a chuck key for model 1140b,f powermatic drill press,manual part number 6285469.
There are only a few sizes of chuck key. Easiest thing to do is first find a drill bit that fits in the hole where the key goes to determine the size of the pin on the end of the key. (Use the back end of the drill bit.) Then take any other chuck key you have and see how closely it fits or doesn't fit - just as a reference. Take the reference chuck key and the drill bit with you to Sears or any place that sells a good assortment of tools. You will probably be able to determine the correct size key from what they have available very easily. Good luck, Al K
Mar 14, 2011 | Powermatic 1140 B,f 14 " Drill Press...
Hi, We have a C188FX Journeyman drill press but no manual. we don't know how to change the speed. Can you help? We would like to find a manual for future questions as well.
Open the top and move the belt to different wheels. There are different size wheels the belt rides on for multible speeds.
Jan 23, 2011 | Drills
Replace belt
Nov 17, 2009 | Drills
Chuck key
As a start, use drill bit that fits into blind hole in chuck, note size and find chuck key at hardware with same diameter
Oct 26, 2009 | Clarke Power Products Clarke 16-Speed...
Drills Logo
54 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
