Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
650 sub zero fridge on 54 says needs service... everything warm f
Please help will not stay on cooler temp...what could be wrong? I turn it down it goes back up to 53 degrees....help...the gridge part freezer still working..
  • freyablock Feb 11, 2009
    sub zero 650 freezer jumps up to 40 degrees. How can I get it back down?
  • 163 Answers
Hi!! looks like you have a seal system problem..First make sure that the condensor motor is on and the compressor and indoor evaporator fan if yes..You have a seal system problem..
Posted on Jan 04, 2009
Why is my sub zero fridge model 590 warming up?
Hi fridges will warm up on the outside as they remove heat from the inside. excessive heat with not extreme cooling inside the fridge indicates a possible degridation of coolant fluid or a leak. as the motor tries to cool the fridge the thermostat inside stays on as the tempreture inside has not been reached. if you hear the motor/ pump continually running this will indicate a cooling problem.
May 28, 2014 | Sub-Zero Refrigerators
I have a Sub Zero 650. The fan on top runs all the time. The temperature inside both Freezer and Fridge are fine and will respond to the changes I do to the settings. The fridge had been off for a move and...
If either compressor is running the fan is always on to cool both compressors. As they cycle it is possible the both compressor cycle at the same time and the fan turns off. But it is rare to see this happen. So yes the fans for the compressor does run at the time. I hope this helps, good luck
Jul 30, 2013 | Sub-Zero 650 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Subzero 650 fridge temp says 34 but is really about 50
Is your thermometer in a glass of water? That's the way to get an accurate temperature reading. You may want to call an authorized servicer.
Jun 15, 2009 | Sub-Zero 650 / O Bottom Freezer...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650-display
If you cleaned out the condensor unit, your problem is probably a bad evaporator. Schedule a service call. If the condensor was really dirty then you may have just compacted the dust into the condensor in which case a shot of CO2 would be a good idea.
Oct 03, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
That depends on if your model has a five or ten year warranty on the compressor. Your problem may not be warranty related. Check and see if the condenser is clean, check for a frozen cooling coil.
Jun 02, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
291 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
