Question about Casio Cell Phones
How do I get pictures off my Casio G'zone S with a broken screen?
I have a Casio G'zone type S, the screen is broken, but I wanted to get the pictures off of it. I have the USB cord, but my computer will not recognize it? I've tried to find a driver for it... but no luck. Any suggestions?
  • kamikaze_cow
    kamikaze_cow Nov 12, 2012
    The phone doesn't have a removeable memory card & I tried to go through "my computer" & click the USB drive, it said it was empty? maybe it's just my computer. Maybe I should try a friend's?
tjzteddy
  • 53 Answers
SOURCE: computer not recognizing camera
search your camera for the option of changing between PTP mode and Mass Storage mode
Posted on Jul 31, 2008
  • 61 Answers
SOURCE: Motorola VE 440 computer does not recognize when connected w/USB
you might want to try it with a computer running Windows Vista - older operating systems will generally tell you that something is plugged into the USB port but will not allow you to access it as it does not recognize new software.
Posted on Mar 19, 2010
OnkyoOwner
  • 12 Answers
SOURCE: computer will not recognize wd1600c032
open up the case and pull the driver out. put the jumper to SL (slave) and plug it directly into *********** boards ribon cable after your windows drive (XP), if it does not recognize it try moving the jumper to the CL (cable select) see then, remember to turn off your computer before doing this each time. if either computer still does not see the drive the drive is probably bad. they dont last a long time if you leave it turned on and running all the time. they tend to get hot and burn out. if the drive it self is SATA you will need an adaptor, if its IDE (wide ribbon cable) it should plug in and be seen. hope this helps.
Posted on May 09, 2010
Martyn01202
  • 217 Answers
SOURCE: my fantom hd tfd500u16 is no longer recognized by
Is this an inbuilt drive or an external drive? If you're using USB, it needs a USB connection. It shouldn't need drivers as the computer will automatically detect a hard drive.
Have you tried connecting to a completely different computer to see if that recognised it?
Posted on Dec 30, 2010
jas247
  • 844 Answers
SOURCE: Four month old Acer Aspire 5336-2634 and the
Welcome to FixYa!
I assume that you have a Windows 7 operating system.
Solution 1. Run the "Auto detect and fix utility" of Windows 7. Click start, then type "find and fix problems" in the search box. On the results, click "find and fix problems with devices".
  • A windows will show up, click "next".
  • It will try to detect and fix a non functional device that is attached or inside the computer.
Solution 2. Do an online auto fix from Microsoft. Keep me posted. Thanks for using FixYa.
Have a great day. Jas247
Posted on May 10, 2011
Casio g'zone phone with broken screen main screen.
This is most likely a broken data ribbon. It is a few very thin wires that connects the mother board of the phone to the screen and can easily break with flip phones. It can be replaced and new data ribbon is cheap.
Oct 05, 2013 | Casio G Zone C751 Ravine Verizon Cell...
How to replace a CASIO G'zOne COMMANDO Camera lens
its a complete small camera unit an they dont sell parts except what you see on ebay from broken phones
Mar 11, 2013 | Casio G-zone Commando
How can I download pictures with no screen with the G'zOne?
If it has a memory card, with photos stored on it you can put the card into your computer reader and download them. Otherwise, you need to see it you can find software (use google to search) for your phone and use cable to connect it to your computer. If neither of these work, trash the phone and chalk it up. Get one that uses a memory card.
Dec 20, 2012 | Casio G''zOne Type S Cellular Phone
Can't save mms pictures
which plateform have this phone??????
Oct 27, 2012 | Casio G-zone Commando
I have an error message Registering Applications. Can't get past this screen
I may have fixed it. i have the same problem with my Casio Type-S on getting stuck on registering applications. i found that as soon as your keyboard lights up right before phone vibrates hold down the clear and the power button at the same time as soon as the keyboard lights up. it will for some reason by pass the app and work. but i had to keep doing it every time i turned my phone off and back on.
Jan 09, 2012 | Casio G''zOne Type S Cellular Phone
Inside screen is broken on my Casio G'zOne Type S. I need someone to guide me thru exactly what buttons to push to enable Mass Storage Mode to transfer all my data!!!! help
Hi well that's no good... However you also maybe able to replace the screen if it is just broken, to do this all you need to do is obtain a new screen and replace it, it isn't too hard of a task, a little "Fiddly" but if you are careful it's easy. Usually these can be obtained on Ebay or the 'net, and often come with all instructions and tools to do the job.
To get the Data off and transfer into Mass Storage mode? Well there is a couple of ways to get the data off the phone, One take out the SD card and use a USB - SD Memory card reader and pop it into a PC and simply use it like a drive. or use the manual link below to download your manual, and inside in detail you will find the steps required to put your phone into the "Mode" you need. You may need to obtain a "Driver" for the phone and install it into the PC you wish to use? This will all be in the manual though, as they are all different.
below is your user manual.http://www.nec-casio-mobile.com/support/download/GzOne_TYPE-S_Eng_v1_1.pdf
Also one can obtain software to "Clone" your phone, and or SD memory card, should you wish to do this? Simply search the 'net and download and use whichever program you like the look of and feel will be the easiest to use for you.
Oct 19, 2011 | Casio G''zOne Type S Cellular Phone
Trying to find where bluetooth info is located on phone it is a casio g zone
hi,
Setting & Tools
My Verizon ~ Tools ~ Bluetooth Menu ~ Sounds Settings ~ Display Settings ~ Phone Settings ~ Call Settings ~ Memory ~ Phone Info
In tools you get Bluetooth info
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Casio G''zOne Type S Cellular Phone
How do i remove a broken screen to replace with another from another phone. inside screen. just glass broken
Is just the glass broken? The LCD screen underneath the glass also could be broken. But if it is just the glass in front of that, go on ebay and search for the inside glass lens. Also, you can find directions to change anything at all just search it on google.
Nov 27, 2009 | Casio G''zOne Type S Cellular Phone
Broken phone
Have a look around ebay and see if you can locate a faulty phone that would have the parts you need.
www.ebay.com
here are the details to casio parts department
http://www.casio.com/support/buyparts/
Jan 17, 2009 | Casio G''zOne Type S Cellular Phone
Cell Phones Logo
302 people viewed this question
Top Casio Cell Phones Experts
Computer Repairing
Computer Repairing
Shehu Pro
Shehu Pro
Are you a Casio Cell Phone Expert? Answer questions, earn points and help others
