Question about RCA HDLP50W151 50" Rear Projection HDTV
When picture has alot of white it shutters and flickers reallybad
The picture flickers and shutters really bad when there are alot of white of lite colors on the screen also it there is a constant screeching noise in the back of the tv really annoying, I just replaced the lamp about a year ago
  • Anonymous Jan 30, 2009
    I have the same problem the tv is almost 2 years ago we sent it in for repair an got it back the same way do any of you understand what could be the problem
My color wheel went out on mine and it looks to be the same on yours'. RCA cannot find a replacement for my model and there are none available on an on-line search. RCA may end up replacing my set.
Posted on Jan 05, 2009
Plasma tv takes time to start then picture flickers really badly then picture returns as normaal for a few hours then goes black but still has sound i turn off tv for a number of hours & repeat the...
This tv seem to have two problems.The problems that the tv take a long time the tv to turn on,the tv power supply board have dying capacitors most likely.That the board where the power a/c cord plug into it.The picture flickers badly this problems is harder to determine because this causes by two backlight buffers boards X,Z buffers boards could be either one it is dying.This tv should get an estamate by a shop or shops and repair it by them,bcause the tv must have to be doing replacing x munbers capacitors components to the tv power supply board and alot more work to trouble shoot and to detrmine which of the buffers boards it is the causes of to the picture screen to be badly flickers and replacing it.
Jun 10, 2011 | LG 42PX8DC Plasma TV
Sticky shutter inside the lens
Not sure that you really mean shutter, or the automatic lens cover. See the description below for a stuck shutter. If that's not what you meant, then see this instead. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 05, 2011 | Olympus Cameras
All outside pictures come out very white. Inside seems to be okay. Have tried 'reset' but still no good.
Jun 04, 2011 | Casio Exilim EX-S600 Digital Camera
Hi, I have a Cannon Powershot A610 and when I take a picture the picture comes out too dark. How can I adjust the it? thanks
"Too dark" or do you really mean "totally black"? I'm asking because a stuck shutter is a very common failure mode for your particular model camera.
Apr 06, 2011 | Canon PowerShot A610 Digital Camera
My camera has a black screen. It has the info in white letters, but no view of the subject.
Dec 23, 2010 | Canon PowerShot S2 IS Digital Camera
My camera cant photoshoot on outdoors, everything that captured looks white. When I photo shoot in our house -- dark room, it seems fine, but WHITE HORIZONTAL LINES appear? I've already used it about 3...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. By the way, recommend trying the pencil tapping method described in this article for a stuck "open" shutter.
Jul 31, 2010 | Canon PowerShot A470 Digital Camera
The pictures I take outside are white.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
When taking pictures there are lines across the pictures and sometimes the picts are really bright or discolored. What could be the cause of this?
Jun 30, 2009 | Canon PowerShot SD600 Digital Camera
White screen for all outdoor pictures
Sorry to say this sounds like a stuck open shutter mechanism. Put the camera in any mode other than auto and make certain that you turn the flash OFF (you don't want to blind yourself in the following step). Next look down the center of the lens barrel and take a picture. You should see a tiny flicker (wonder where that website got that name?) in the center of the lens as the shutter opens and closes. If no movement is seen then it's likely stuck.
Some people have had success in unsticking Canon S2 IS shutters with the following procedures. It may or may not work for you:
http://www.fixya.com/support/t295396-canon_s2_black_screen
May 09, 2009 | Canon PowerShot SD30 Digital Camera
Display problem
Sounds like your shutter may be stuck. Turn off the flash (so that you don't blind yourself), then look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter/iris quickly opens and close. If no movement is seen then the shutter is stuck. Unfortunately, professional repair will cost many times the current value of the camera. But you can try the following fix to try to unstick it:
Jan 30, 2009 | Canon PowerShot A410 Digital Camera
RCA HDLP50W151 50" Rear Projection HDTV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
