Question about Maytag Washing Machines
Maytag atlantis mav8600aww
Washer goes thru cycle but drains out the bottom instead of hose
    Top Expert:
  • Maytag Master
  • 9,472 Answers
There should be and access panel on the rear, lower left side of the washer. This is where the drain pump is. Remove this panel to see if the hose has come off the pump or if it is broken. Here is the new pump in case you need it.
Posted on Nov 01, 2012
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
SOURCE: Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Posted on Feb 15, 2009
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
SOURCE: Maytag Atlantis Mav8600aww
I have a maytag atlantis mav8600aww and the machine won't spin and drain water out.
Posted on Sep 26, 2009
aasc
  • 1606 Answers
SOURCE: shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Posted on Oct 11, 2009
Testimonial: "Thought it might be a belt rather than the pump."
Hello, I have a maytag atlantis MAV6000. Everything works fine except when the washer goes to spin cycle. Instead of any of the water draining properly, it all slowly leaks out of the bottom of the...
This is the car and truck section, you may want to repost this in the washer section.
It sounds like the drain hose or pump is stopped up.
Aug 28, 2012 | Cars & Trucks
Water draining from bottom of washer when I went to fill up. Completely drained all over floor within minutes. What the heck is going on?
Have you checked your hoses in the back? The water may be going to the floor instead of the washer. Check around the water pump as well.
Mar 05, 2011 | Maytag Atlantis MAV6451 Top Load Washer
Washer won't drain
look for blockage in hoses and pump.
Sep 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
When the washer goes to the rinse cycle it does not fill it just keeps running water in the tube.............Maytage Atlantis
check washer drain hose if it is all the way in your drain line take out put it back only 6 to 8 inch in your drain line. i think i will solve your problem.
May 21, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washing machine will not drain
your water pump may be jammed with a sock or something..its in the bottom of the machine
Nov 15, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine will not drain
Please fill your washer with a very small amount of water, turn it to spin and tilt it back. You should be able to see the belt on the bottom turning your pump. I ask you to verify this because imporper belt tension or a bad thrust bearing can keep it from turning improperly. If it turns freely on this test, Then you have something plugged up. Drain the water out. Next unhook the hose that goes between the tub and the pump at the tub side. You can get sock or other small articals of clothing in there that will prevent draining. If that is clear. It is likely you have had another coin go through your hose that goes between the pump and the wall. They can get quite a ways in there and maytag hoses get smaller right before they end. If you have a coin in this area you will need to work it all of the way back to the pump side of the hose.
Jun 02, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer Maytag
the drain hose tear or broken/ clamp detached / need to replace.
Dec 26, 2007 | Maytag Atlantis MAV6000 Top Load Washer
If your timer has a gray rubber ring on it, the timer is in 4 pieces. Pull the top middle part out. Then there's a white locking piece in the center. Once that's out the other 2 pieces will pull out. Note: The photo shows the top cover removed. The locking pin is the white center. RanchMom
Apr 10, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
