Question about Toshiba Computers & Internet
HELP. my laptop will not go past the stating up of toshiba. have tried the f12 and f8 and it just says loading but nothing happens
  • Toshiba Master
  • 7,627 Answers
Have you tried a "Cold-Start" ? unplug laptop, remove battery, hold down on/off button for 10secs or so. Replace battery, plug in laptop, re boot. Does it get to the pre-boot stage? does it show the options BOOT MENU, SETUP, BIOS or similar options?
Posted on Nov 01, 2012
MysteryFCM
  • 187 Answers
SOURCE: Failure to boot
In these cases, I'd strongly recommend checking the RAM to ensure that isn't the problem. If the RAM is fine, then the issue is likely with the laptops motherboard. In which case, it would need to be sent back to the manufacterer.
Posted on May 25, 2008
ahmdrgb
  • 5 Answers
SOURCE: toshiba satellite start up
maybe you lost your COMS you should recharg it
Posted on Jan 19, 2008
  • 43 Answers
SOURCE: toshiba A105 will not boot up even with cd and f12
its not a booting issue if you hear the music, it loaded windows. you might have a display issue, shine a light on it to see if you can see any faint images, if you can the backlights out if not it might be the display adapter on the MOBO, in either situation calling toshiba would be required for a repair, or otherwise take it into a shop, but first try a power reset,
unplug it and remove the battery, then hold the power button down for one minute, replace the battery and power cord and try to boot again. if this fails call toshiba, its definately a hardware issue.
Posted on Jan 24, 2009
SOURCE: My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
Posted on May 08, 2009
boylaptop
  • 62 Answers
SOURCE: BIOS STUCK OF TOSHIBA L305D-S5934 NOTEBOOK NOTHING
Try upgrading ur BIOS from flashdisk...
Posted on Apr 05, 2010
Laptop gets stuck welcome screen when
It sounds to me like a file is corrupt and there is a number of reasons for that. If you press F8 just before it tries to boot, you will have access to a menu. Try running safe mode to see where the issue is.
To run Toshiba Recovery:
Choose the Repair Menu in the Windows boot menu (Press and hold F8 at the Toshiba SplashScreen.
Or
Hold the Zero key during Power Up.
If that doesn't work, you may need to order a Recovery Disc from Toshiba.
Mar 07, 2014 | Toshiba Computers & Internet
Free unlocking codes for toshiba
Best Buy Geek Squad has a special CD to delete the password.
Dec 26, 2012 | Toshiba Portege 2000 Laptop AC Power...
Cannot get into the setup. tried F2, F12 and F8. Nothing. Any help into how to enter the setup?
try F1 when you turn the laptop on and you see the post screen start opressing the F1 key
Feb 19, 2011 | Toshiba Satellite A10-S177 Notebook
When turning on the computer the first screen comes up stating Toshiba and at the bottem it says push f2 for set up or f12 for boot device selection menu but when you push a button nothing happens.
Why do you press these buttons in the first place? Did you have problems with the stability of your system so you want a different boot option?
If your laptop was experienicing random freezeups and you couldnt get it to boot at all, and nothing you do can get you past the Toshiba startup screen then your laptop may have a bad motherboard. Actually, it's more of a loose contact between the FSB controller chip and the motherboard. Take a look at this laptop motherboard repair tutorial for bad FSB chip contact, see if that may be of any help.
Jan 18, 2011 | Toshiba Satellite A215-S5837 Notebook
Hi im having trouble with getting my desktop to come up. its just showing start thats it and saying location is not availble
It sounds like you have maybe two problems.
Firstly, press start and when it shows the BIOS menu, press F2. Select default settins from the menu and save with F10.
Press start again, if it doesn't try to load after the POST, (BIOS menu) and press F8 as it is starting to boot up. Select Safe Mode and let it run until it has finished loading. Close down and it should have repaired itself. If it hasn't, and I am assuming it does get past the BIOS menu because if it doesn't there is a MotherBoard fault and it will require technical support through Toshiba.
If it doesn't load but gets past POST, as it finishes the BIOS option menu, (F2 or F12) press F8 and select recovery. Follow the prompts and that should sort your problem out.
Hope that helps.
Nov 28, 2010 | Toshiba Computers & Internet
Grey screen with white line on my laptop
I took the battery out then put it back in and it works fine now.
Apr 28, 2009 | Computers & Internet
Failure to boot
May 25, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
