My simpson aquarius 711 wont stop filling it overflows the bowl it wont go on to the agitate stage if i turn water off but it will drain and spin, please help!
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You will need to replace the water level sensor.
Posted on Nov 01, 2012
jsrock516
  • 5911 Answers
SOURCE: My Estate by Whirlpool Corp. TAWX700JQ3 will fill up no drain,spi
The problem is usually related to a lid switch malfunction. The lid switch is located under the right-hand side of the tub rim and is activated by a small plastic piece on the lid, called a "lid strike". First, make sure the lid strike is not broken off. Second, double check the two mounting screws that hold the lid switch in place along the tub rim opening on the right-hand side. Sometimes, all that is required is to tighten the screws that hold the switch in place to realign it with the lid strike. If all parts are in place, open and shut the lid. You should hear a distinctive "clicking" sound indicating the switch is activating. If the switch still does not work, replace it. The following link explains:
http://www.fixya.com/support/r397101-replacing_lid_switch
A replacement switch can be purchased on line at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 9 and the lid strike is listed as item number 20. If you're exact model number is not shown, any of the listed models will do. The part numbers are still the same. You can also try any of the following other websources: repairclinic.com, pcappliancerepair.com and appliancepartspros.com. They all offer great service and competitive pricing. I hope you find this information helpful. Let me know if you have further questions.
Posted on Dec 18, 2008
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
Oceti
  • 51 Answers
SOURCE: Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Posted on Dec 13, 2007
jumptrout51
  • 3361 Answers
SOURCE: will fill and drain wont agitate or spin
Replace the lid switch.
Posted on Mar 11, 2009
jsrock516
  • 5911 Answers
SOURCE: Whirlpool LSR5233EQ0 top loading washer wont spin
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupler that is more resilient and should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Posted on Jun 24, 2009
My Simpson eziset 750 will keep pumping even after water is gone and wont go onto next stage which i think is spin etc, can any one help me with what might be wrong thank you
the program is empty , then spin in stages and rinse, at the same time pumping then stop rinse water then spin up to speed while pumping right to stop at end of cycle
If it doesn't get to full spin then there is a problem in the program board not progressing
call a technician for a proper diagnosis
oh and for your future information , if you have a balance problem , it will be the suspension rod ends broken off and not allowing the pneumatic motion absorbers to work correctly Replacement cost is $88.00 aud and you can do it yourself one rod at a time
there are 3 blue ones and one white one so make sure that you replace color for color then sure that the bowl is level by pulling out the agitator strainer unit and using a short level across the top of the agitator
just done the repair myself , took about 1/2 hour by myself
Apr 23, 2017 | Simpson Washing Machines
My simpson ezi sensor wont agitate
hi just read your posting.Does the machine spin and drain?Please reply with answer and I can help you further.
Jul 14, 2012 | Simpson Washing Machines
My simpson esprit 450 washes dirt/sand into the tub - how can I clean the
Hi just read your posting.The only way you can assess the tank is to remove the inner bowl.This is quite difficult.I can help you with removing the inner bowl but I think the easiest way is to fill the machine on a High water level and when it stops filling and starts to agitate pause the machine and advance the cycle to spin and let the pump drain out the sandy water.Give this a try the reply back on how you got on.
Jul 14, 2012 | Washing Machines
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
Simpson washing machine 8kg ezi sensor watter wont stop running
Hi just read read your posting.Is your machine the Simpson Ezi set? If it is and the water keeps running does it at any stage while it is filling start to agitate? Or does the machine keep filling and does not start agitating?Please reply with additional information and I can help you rectify this fault. Looking forward to your reply.
May 16, 2011 | Washing Machines
Water leaks when draining
sounds like the drain pump is leaking
Feb 21, 2010 | Washing Machines
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
