Question about Giorgio Armani Watches
After replacing battery can't get the backplate of AR0156 back.
I replaced the battery of Empori armani AR0156. The problem is that I am not able to fix the back plate as easily as i could remove it. On placing the backplate, I can place it on either the top or bottom but the other side wont snap. I made sure that The backplate is aligned properly. It just wont snap. Any leads or tips would be appreciated.
  • Giorgio Armani Master
  • 18,411 Answers
If you cannot snap the back on with your fingers the only safe way to get the back on again is to use a watch press. This is an expensive tool that most jewelers will have. I strongly recommend you take it to a jeweler (may want to call first to make sure their company will do it because most chain stores will not work on most brands). They should not charge you.
If you are determined to do it yourself then you can try wrapping a wide pliers with duct tape or cloth and applying pressure on the front and back of watch to pop it on. WARNING: this is very dangerous for your watch. DO NOT apply pressure to the crystal, try to put the pressure on the stell lugs instead...
Posted on Nov 01, 2012
Simplest way to do it is. Get a rolling pin and towel. Fold the towel in half , place the watch facing down on the towel, get the rolling pin and pressure on the back plate with a lot of weight and it should click back in.
Has worked on mines.
Posted on Dec 05, 2014
escapement
  • 2334 Answers
SOURCE: SEKONDA: HOW DO YOU REPLACE THE SNAP ON BACK COVER?
Sorry, but your hands (especialy fingers) aren't strong enough. Nothing personal- just confirming the fact. My hands can handle 50 ATM casebacks, but I would say this is more expierence than strength.
OK, back to business: align the winder groove first and make sure this side of caseback sits in properly in case. Then use your thumbs to push the opposite side of caseback in, supporting the watch by your palms and knees. Do not try to push the caseback in bit by bit going all around the caseback. This sort of action will never work.
So, align the groove, support your palms by the knee(s) and push the opposite (to the groove) side of the caseback in to the watch case by one, but strong attempt with your thumbs. It should snap in.
If this doesn't work, you will need to ask the watchmaker to close the watch.
NB: Watchmakers are using specialized press for closing watch cases wich do not require any strength at all.
Rate me, please.
Posted on Mar 25, 2009
kaicooper
  • 8 Answers
SOURCE: back of watch won't snap back on
that is a common problem...
Posted on Jun 19, 2009
  • 61 Answers
SOURCE: how do i snap the backplate back on my buulova
Posted on Oct 21, 2009
SOURCE: watch battery replacement
I have a Timex Expedition Indigo with a metal case. Not sure of the exact model number but on the back there an M6 below Expedition. Anyway, I had the same problem of snapping the back back on. I found a "battery" website that had some suggestions that should be typical of any snap back case watch. http://www.online-batteries.co.uk/whichbattery.shtml specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment. The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even. Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it. Good Luck, Richard
Posted on Sep 28, 2007
  • 2501 Answers
SOURCE: The back doesn't seem to want to snap back in
Try a very small dab of a very light lubrican on the sealing edges.
If you haven't already tried it, press the edge of the watch back using two fingers and move them appart until they meet again.
Season with a lot of parience... good luck!
Posted on Apr 20, 2010
How to change battery on empori Armani model ar0645
If you take it to a jeweler, you can observe how to open it and may be able to persuade the jeweler to replace the battery.
Jan 21, 2018 | Watches
Is there a video for removing back of Emporio Armani AR 0540?
I wouldn't want to risk scratching up the back of an Armani. If you have a watch repair shop near you, it's better to take it there. I've taken several down for battery replacements, etc. and it has cost between $7-20, battery included. That said, I did find a video, but it's not for the exact Armani model and they used professional tools to do it. I saw another video where you could use standard tools, but you run the risk of gauling the metal on your watch in the process.
Sep 16, 2017 | Emporio Armani Watches
Battery size for emporio armani ceramic ladies watch
  • To determine battery type: open back
  • Locate battery holder and identify type. Note battery mounting
  • Place opened watch in plastic bag to keep it dust-free while you obtain a replacement battery
  • Remove watch from plastic bag and install new battery
  • Check operation
  • Install back
Finally, reset watch as necessary
Aug 28, 2016 | Emporio Armani Watches
Change battery
Usually, you remove the backplate and then the battery. Replace the battery without touching it by hand and replace the backplate.
Mar 08, 2015 | Watches
How do I reset emporio armani ar5950 chronograph to zero after replacing the battery.?
pull crown out to second position ,then press bottom button till it goes to zero then push crown back in job done,,if you want to do both dials press and hold bottom button so they rotate faster to zero then press one press at a time...
Nov 21, 2014 | Emporio Armani Mens AR5950 Brown...
Battery size for Emporio Armani AR0156
eBay might be ur best bet
Jan 07, 2013 | Watches
Armani Exchange AX 1066 in need of a replacement part.
Google is your friend in such cases
Armani Exchange Watch Repairs ' Creative Watch Co
https://www.creativewatch.co.uk/repairs/armani-exchange
  1. Cached
  2. Similar
Armani Exchange watch parts & repairs are available from Creative Watch Co at the Birmingham Jewellery Quarter watch shop.
A'X Armani Exchange Watches ' eBay
https://www.ebay.com > ... > A'X Armani Exchange Watches
  1. Cached
You are here. eBay · Jewelry & Watches · Watches, Parts & Accessories; A'X Armani Exchange Watches. Skip to page navigation. Filter (1). A'X Armani Exchange Watches. Limited Time Deals. Free Shipping Included. Armani Exchange Women's AX5216 Gold Stainless-Steel Plated Fashion Watch. $128.57. was -$190.00 ...
Armani Exchange - New Watch Strap Band
https://newwatchstrap.com/armani-exchange-watch-strap-band.html
  1. Cached
Items 1 - 24 of 44 - You will find the cheapest price for your watches of band types of the Armani Exchange brand.
Watch Straps - Buy Armani Exchange watch straps online
www.mastersintime.com > Watch Straps
  1. Cached
  2. Similar
Masters In Time home · Watch Straps; Armani Exchange. Universal watch straps. Morellato Watch Straps. Strap Brands A-Z. Adidas (34) · Alessi (2) · Armani Exchange (26) · Boccia (15) · Braun (27) · Breil (27) · Casio (532) · Citizen (113) · Cluse (95) · Daniel Wellington (74) · Danish Design (101) · Davis (756) · Diesel (1236) ...
Armani Exchange Watch Repair Specialists - Watch Repairs USA
www.watchrepairsusa.com/armani-exchange/watch-repair
  1. Cached
Armani Exchange Watch Repair Specialists - Get your Armani Exchange watch repaired the fast and easy way. Free Estimates, One Year Warranty.
Watch Parts ' Replacement Watch Supplies ' Esslinger.com
https://www.esslinger.com/watch-parts/
  1. Cached
Find a wide variety of watch parts that come in handy during watchmaking and repair work, such as replacement watch parts.
Armani Exchange Men's Watches ' A'X Store
https://www.armaniexchange.com/ca/men/mens-watches
  1. Cached
Shop the full range of Men's Watches from the latest Armani Exchange collection. Browse the A'X official online store today.
Armani Exchange Watch Straps & Bracelets for Replacement ' Babla's ...
https://www.bablas.co.uk/watch-straps/armani-exchange-watch-straps.html
  1. Cached
Items 1 - 20 of 31 - We also offer a selection of Armani exchange watch straps available by special order. All replacement watch straps are genuine manufacturer replacements. Replacing your watch strap with an original replacement watch band maintains the original appearance of the watch. Please contact us if an Armani ...
Warranty & Repairs - WatchStation Official Site: Watches
www.watchstation.com/webapp/wcs/.../ContentView?...warrantyRepairs
  1. Cached
  2. Similar
Shop Watches, Wallets, Bags, Belts, Sunglasses, Jewelry & More for Men and Women. Incredible looks at ... Click on the corresponding link below to download a PDF of a specific brand's warranty, US-only repair form, or international service center information. To view PDF files, you will ... Emporio Armani Swiss. Warranty.
Armani Exchange Watch Repair - Total Watch Repair
https://www.totalwatchrepair.com/pages/armani-exchange-watch-repair
  1. Cached
Total Watch Repair provides online Armani Exchange Watch Repair Services including battery replacement, band repair and internal mechanism repair.
armani exchange watch replacement parts Google Search
Dec 27, 2017 | Watches
Hi, I got the Georgio Armani AR0156 watch today as a present. It is not working, I'm not sure but the battery seems to be dead, which is a bit odd since I only recieved it this morning, what do you thinks...
It might be that the watch was running when packed and it has been in stock for some time.
On the other hand there might be an insert between the crown wheel and the body to prevent it accidentally starting. Have you looked closely at this point?
If you can't find anything, then is should go back to the supplier (they may need proof of purchase).
Mar 10, 2011 | Giorgio Armani Emporio Armani Black/Steel...
Beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
May 31, 2009 | Timex Watches
Watches Logo
4,251 people viewed this question
Top Giorgio Armani Watches Experts
Ansel Alberto
Ansel Alberto
Kolbrun...
Are you a Giorgio Armani Watch Expert? Answer questions, earn points and help others
