Question about Baby Gear
Installation guide 22-862-ebc car seat - Baby Gear
    Top Expert:
  • 14,161 Answers
Posted on Mar 18, 2016
What would cause trunk lid and fuel filler door to fail at same time. I have checked under bonnet fuse but it is ok
I believe those are cable operated, a lever down beside the seat? If so I'd check to see that the cable/s are still connected to the lever and not broken. If they are electric, I'd look at a wiring diagram and see where they are connected.
Feb 01, 2015 | EBC Brakes 2003 Hyundai Sonata - 2.7L V6 -...
Front disc brake pads
Hi Anonymous, for more information about your question please visit the website below. Good luck and have a nice day.
What are Brake Pads Made Of
Motorcycle Brake Pads Buying Guide
EBC Brakes
Brake Pads break down of what you need to know Pinkbike
ebc brakes HH brake pads
Feb 05, 2014 | Bajaj Motorcycles
How to fix a childs car seat in back seat of car
Watch this video that demonstrates how to install a car seat in the back of a car: http://video.about.com/babyproducts/Install-a-Toddler-Car-Seat.htm
And read these articles that provide information about how to install a car seat: http://www.babycenter.com/0_installing-a-car-seat_9458.bc
http://www.dmv.org/how-to-guides/install-child-seat.php
Jan 11, 2013 | Baby Gear
Need to know where ebc module is located in a 1990 toyota camry
The Electronic Brake Control (EBC) module (A.K.A. ABS computer) is mounted in the trunk area under the rear deck below the back glass. (see picture)
Jul 22, 2011 | Toyota Camry Cars & Trucks
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
Install seat belt through seat belt guide 1990 camaro
The new seat belt guides will have a **** in them that allows you to put the belt through it. If it's a used guide taken off another car it may not have the ****.
Mar 16, 2009 | 1990 Chevrolet Camaro
How do you remove the headrest on a 1996 ford crown victoria?
Head Restraints Each front seat is equipped with dual-post design front seat back head restraint (611A08). The front seat back head restraint is installed as follows:
  • It travels on dual posts which have notches to engage a spring-loaded catch in the guide.
  • The front seat back spring assembly retains the front seat head rest guide rod sleeve (610A16).
  • The front seat back head restraint is adjustable from its normal position to a raised position of approximately 25 mm (1 inch).
  • Pull up on the front seat back head restraint to raise it. Pushing down will return it to its normal position.
Removal
  1. Unscrew front seat head rest guide rod retainers (610A18).
  1. Pull up on front seat back head restraint (611A08). Compress foam in area of front seat head rest guide rod sleeves (610A16).
Installation
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves.
  1. Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve.
    Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint.
Mar 01, 2009 | 1996 Ford Crown Victoria
Baby Gear Logo
319 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
