Question about JVC Televison & Video
Power supply shuts off immediately after it turns on
  • JVC Master
  • 5,807 Answers
Many things to consider.
If you need to DIY post images of your TV board to help you.
Posted on Nov 01, 2012
Laser printer shuts down immediately
A laser printer that shuts itself down immediately after turning it on indicates either a loose power cable which can be fixed by pushing the power cable in properly or something internal to the printer is causing it to shut down.
If it is shutting down due to something internal, one possability is it has the wrong power going into it. a 110 volt power supply going into a 220 volt printer or the other way round change the supply or find a converter for it. Another possibility is some other component in the machine is failing such as the power regulator board or format board. If it is something internal like this. Replace the printer is really your only option unless it is still under warrantee as replacing parts in most machines nowdays is more expensive than buying a new printer.
Aug 19, 2014 | Brother HL Office Equipment & Supplies
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
When I turn my television on it auto turn off after a few seconds. The light starts to blink when I first turn the tv on and then the Tv just shuts off on its own.
Hello Sir, hi, you have power supply problems, this is caused by a bad part on the main board or on the power supply board to overload, when overload happens, the power supply immediately shuts down to prevent further damage. my first advice is call your dealer for proper service.
Dec 07, 2010 | Mitsubishi WD-60C9 60" DLP HDTV
I push the Power button--but usually have to go thru many tries before machine turns on. It was suggested to remove the PWR plug from the ASUS motherboard and replace it with the RST plug. First time thru:...
hi , by your description i would say the relay in your power supply is deffective , its not a cost effective repair , so change the power supply
hope this helps
Jan 10, 2010 | Antec CASE |P180B BLACK RT
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Tv shuts off immediately after turning on
Does it shut off shut off, or is there audio present after the lamps shut off? When you shine a light to the screen do you still see picture kind of?
If still see picture, it's inverter/power supply or CCFL bulbs itself. If no picture, completely off, it's DEFINITELY the inverter/power supply.
Sep 30, 2008 | Televison & Video
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
