Question about Panasonic Lands Phones
Pansonic KX-TG234 keeps beeping from base
Power was out for 24 hours, now base keeps calling all phones at odd times of the day and night (I think trying to register them again) and it won't stop. How can I get this to stop, intercom beeps at 2 and 4 AM (and during the day but not at regular intervals). It did it when I first got the phone and I don't know what I did to stop it (the manual was of no help). HELP BEFORE I LOSE MY SANITY
    Top Expert:
  • Panasonic Master
  • 78,238 Answers
Unplug all the phones and charge stations and base station for 5 min's and see if the system resets.
Posted on Jul 25, 2017
SOURCE: Phone beeps during calls
If its a double-beep, its normally an incoming call alert, which you hear when you're already on the phone. Its alerting you, so you can answer the incoming call. If you don't want call waiting, then you can turn that off in your phone's "call" settings.
If its not that, then it may be the in-call alert set to beep for every minute that passes. In your phone settings, you should be able to find this in your "in-call" or "call" settings.
Posted on Mar 19, 2008
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Posted on Jun 23, 2008
SOURCE: Merging 2 siemens gigaset 4215 systems (one base with 2 phones + 2 phones)
If you're trying to get 5 handsets to work with one base, it won't work. The 4215 can only handle 4 handsets, the base handset plus 3.
When I had to replace the base of my 4 handset system, the base handset still worked. Therefore I had an extra handset which couldn't be used. So I decided to buy another base. Now I have 6 handsets which can be grouped 4,2 or 3,3.
Posted on Aug 27, 2008
cnavarro
  • 2460 Answers
SOURCE: panasonic kx-t7330 suddenly cannot use intercom and phone calls
I'm guessing the phone is 8 years old and you spilled something into the keystrip.
Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
Carl
Posted on Feb 24, 2009
How do we keep our Panasonic KX-T7731 from changing back to night mode? I recently reset the time and every time I do it changes to night mode. How do I permanently set my phone system on day mode?
This has about 5 different conditions, so let me start somewhere.
Pretending your 7731 is connected to a recent Panasonic KSU, like a TA series, you have the ability to set the time by hand, or CID delivered in the first call after 2 or 3 AM will do it. If the sender is still on standard time (typical with VoIP delivered CID), then it will reset the clock to a different time (-1 hour) every day and it will be noticed if you set the clock and the first call of the day follows.
In addition, via programming from the main phone, you can set manual or automatic switching for day, night, and lunch modes. That procedure is outlined in the Programming Manual for your system, but it involves setting the clock times in Maintenance console 1.4 or programs 006 and 007.
If you absolutely want to never have to deal with clocks or night mode, then set 006 to manual and dial 781# on the intercom from the main phone (x101).
Note that this is only the solution for TA series KSU's.
Mar 17, 2011 | Panasonic KX-T7731 Corded Phone
It said base no power
Remove then replace the batteries from the hand set. You should now get dial tojo.
Oct 25, 2010 | Panasonic KX-TGA101S Cordless Handset
On 308 pansonic pbx (kx-t7730), when the incoming call rings all the extension phone and the master (PT or operating console)phone rings.so please help me to make it ring only on the master.thanks
When you take this unit out of the box, you get programming instructions. One of them is the ringing (program 408) for day mode. (409/410 for night and lunch). By default, all phones ring on all lines in all 3 modes. You have to remove the ring to make it go away.
Carl
Sep 29, 2010 | Panasonic KX-T7730 Corded Phone
I have a 3 set of the above system KX-TG1033S. No dial tone
Try power cycle , or Reset base ,from handset menu . Check it out if there is reset menu in menu/setting /reset ...simular like that .
Feb 21, 2009 | Panasonic KX-TG1033S Cordless Phone
I have a panasonic KX-TG2336S cordless phone and when you try to make a call the handset displays "no link to base". Can this be fixed or is the phone shot?
Just in case you don't have a manual
http://service.us.panasonic.com/OPERMANPDF/KXTG2336.PDF
Page 55 lists your trouble and gets you to page 49. You take the bandset and base, press the locator button on the base and then press the flash/recall button on the handset until Handset Registering appears on the display. If it beeps one time, wait 20 seconds and it should register. If it beeps 3 times, keep trying.
Carl
Jan 18, 2009 | Panasonic KX-TG2336S Cordless Phone
Turn off ringer?
On the base, to turn the ringer off, press and hold Volume Down [V] until the unit beeps 2 times. On the handset you can use the menu to turn off ring. This way, you can choose to receive and take the urgent calls.
Apr 04, 2008 | Panasonic KX-TG2313 Cordless Phone
Phone calls going to voice message without ringing while person is there.
Question: What does this have to do with a Panasonic KX-T7425 phone? Is a Panasonic phone hooked up to your Partner system?
Sounds like the system believes the phone is in use. Is the partner phone in question an MLS model? MLS-6, MLS-12 etc.. They all have keypad problems and buttons could be activating on their own randomly, making the phone in-use on the system. The message waiting light may not come on until the phone is no longer in-use. Usually phones with this problem will at least beep randomly when it thinks the buttons are being pushed.
Oct 11, 2007 | Panasonic KX-T7425 Corded Phone
Base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Jun 19, 2007 | Uniden TRU9480 Cordless Phone
Lands Phones Logo
1,409 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
